Engine Tune-Up
Old 10-13-2006 | 01:33 AM
Costco's Avatar
Engine Tune-Up
Just wanted to compile a list of things for an engine tune-up. There was a bunch of crap I remembered, but I just forgot. I know I'm missing several things, so add to the list if you can, please. FYI I am going to do this on a 1997 Honda Civic EX w/ 128000 miles
Oil change (its about time anyway)
new spark plugs
New spark plug wires
clean and lube throttle body
clean IACV
change air filter
and should I reset the ECU?
On a sidenote.... if I seafoamed the car, would it be recommended to do all of the above afterwards? Thanks
Old 10-13-2006 | 02:23 AM
SpeedyV6's Avatar
Doesn't resetting the ECU merely involve disconnecting the battery? If so I would expect you to do so if you're going to take out the spark plugs.
Old 10-13-2006 | 06:45 AM
KaMLuNg's Avatar
fuel filter....
cap and rotor...
i would also give the engine a wash after all is done too..
Old 10-13-2006 | 08:32 AM
aaronnn's Avatar
why not clean the throttle body and clean out the intake manifold while at it?
Old 10-13-2006 | 08:41 AM
RaviNJCLs's Avatar
Tranny and brake fluid. Coolant.
Old 10-13-2006 | 09:42 AM
Bdog's Avatar
Not Registered
Valve adjustment and check timing.
SidhuSaaB
05-30-2020 12:40 AM
BIGxRED
10-19-2015 10:47 PM
joflewbyu2
10-08-2015 11:16 AM
ROSSARONIE
10-02-2015 11:46 AM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: Engine Tune-Up
