Dont Fill Car with motor running
[]( O)( O)% []D[][]V[][]D
hey guys...i just thought i should let everyone know not to run their engines while pumping gas, not just for saftey reasons, but it's been "proven" that when pumping gas (especially when empty) u can kick the dirt up that is sitting on the bottom of the tank n very easily get sucked into your fuel lines n clog up your filters, possibly couse damage to ur motor......hope this help, it's the holiday season n i figured this would be a great tip for our fellow TL'ers........MERRY X-MAS
:padlock:
:padlock:
Huh? The dirty that sits in the bottom of your tank? Where do you think the fuel exits the gas tank? That's right, at the bottom. So why would it matter? Also, you don't think driving around displaces the dirt? I think you've had one too many spiked egg nogs.
take it as if ur filling n empty bucket...if theres a bit of dirt stuck to the bottom, when hit it with the hose the dirt tends to break away...but when the fluid is already in there n fuel moves around due to driving...dirt still sits in the bottom of the tank :oD
Originally Posted by eyesnake02
dont gas station make u turn off ur car first?
Received 2,329 Likes
You should shut off the engine as a common courtesy to others if anything.
Originally Posted by REDLINEN
Its really a matter of who ya are to each his own but its like freezing out and when its cold the engine stays running with the heat on!
I forgot about those New England winters for a sec.
Missing my Acura's
Well no booms yet and I been doing it for about 7 years now. And no the car wont go from warm to cold but I get back in while the tanks filling. The pump will stop on its own when its full.
just because you've been doing it for some odd years, doesn't make it the right thing to do. I would think that its pretty freakin obvious that u shoudl turn off the car. Like someone else said, it only takes a coupla minutes to fill the tank.
I've always heard your supposed to turn off your car as well. It has to do with safety precautions, as someone previously stated. I agree that it's foolish to believe that since something hasn't happenened, it won't.
....and dont forget to turn off your cell phone at the pump as well.
The fuel pumps from the bottom of the tank. If it pumped from anywhere else you would always have some fuel left. So nothing really "settles." Also, as someone else mentioned, there are fuel filters for a reason.
