Cordless Impact Wrench
I would love to buy an air compressor, but I simply do not have room for one right now. So, I figured that the next best thing is to purchase a cordless impact.
I'm trying to decide between the Ingersoll-Rand W360 w/Li-Ion or the Snap-On CT4850HO.
1) Ingersoll-Rand W360 Li-Ion Starter Kit:
http://www.tooltopia.com/index.asp?P...D&ProdID=48496
2) Snap-On CT4850HO:
http://buy1.snapon.com/catalog/item....group_ID=19913
I only plan to use the impact once or twice a month, at most. It'll be used for brake and suspension work.
What do you folks think?
Thanks!
Thanks!
Not Registered
For what little use you'll have I'd get a DeWalt for $169.00
DeWalt DC810 Heavy-Duty 28-Volt 1/2-Inch Cordless Impact Wrench With Nano Technology
http://www.toolking.com/products/220...oglebase=DC810
LFG RANGERS!!!!!!!!!!!
IR DD2T2, it is small and runs almost continuously when using it on the 2135 but gets the job done.
I got it for 265.00 locally at an IR outlet store here in Phoenix.
http://www.ohiopowertool.com/p-1178-...sor-dd2t2.aspx
# The Ingersoll Rand Twin Stack hand-carry air compressor is designed to provide power, durability and portability on the job site.
# From interior trim and finish, to roofing and decking, framing and sheathing or heavier construction applications, the Twin Stack can do the job.
# Built to last, this oil-lube compressor with a durable cast-iron cylinder is designed for the toughest 100% continuous duty applications.
# The Twin Stack includes a 1/4-inch universal coupler, conveniently mounted regulator and pressure gauge, 4.5-gallon twin tanks, All Season Select lubricant and a power cord.
# Lightweight and compact hand-carry size
# Durable cast-iron construction
# Extended pump life double the life of similar oil-free products
# 125 Max PSI
# 4.4 ACFM
# NPT outlet 3/8 in.
# 125 Max PSI
# 4.4 ACFM
# 125 Max PSI
# 4.4 ACFM
# 125 Max PSI
# 4.4 ACFM
What do you think of this new Milwaukee impact?
http://www.northerntool.com/webapp/w...9725_200389725
- 450 ft-lbs of torque (Snap-On is 400 ft-lbs)
- 5-yr warranty
- Comes with two lithium-ion batteries.
I heard Milwaukee's reputation is top-notch as well.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
