Cooling system problem..
Old Jan 14, 2010 | 01:33 AM
tmnhs81's Avatar
I have this 1997 Accord LX I have this cooling system problem with it.
Its a 2.2 4cyl non-vtec automatic. Problem is when car heats up it will push the coolant into the coolant reservoir, which is normal but it won't suck it back in when needed. Reservoir overflows and coolant drains through the cap just like busted radiator. Thats why car overheats sometimes. (210* F). I have already replaced radiator cap but no avail. Any idea what the problem might be?
Old Jan 14, 2010 | 08:35 AM
fsttyms1's Avatar
Have you replaced the thermostat or done a pressure test on the system?
Old Jan 14, 2010 | 10:07 AM
dallison's Avatar
registered pw
and a thermostat should only be about $10
Old Jan 14, 2010 | 11:40 AM
Pure Adrenaline's Avatar
Dragging knees in
+1
Check the thermostat. It may be malfunctioning.
It's pretty simple to test it. It's the removal/installation process that may be a pain in the butt.
Take it out and put it in boiling water. Keep watching and see if the thermostat expands. Take it out and see if it retracts. If it does, then it's working fine and the problem is something else.
Old Jan 14, 2010 | 01:57 PM
tmnhs81's Avatar
So I bought thermostat and I am changing it right now. Hope this works..
Old Jan 14, 2010 | 02:21 PM
Dragging knees in
I would've tested the current unit first before spending money on a new one. It takes 2 minutes to boil water.
If it's not the t-stat, then I would venture to guess a problem with the water pump.
Old Jan 14, 2010 | 05:28 PM
tmnhs81's Avatar
I am done replacing t-stat but now fans won't turn on. If I turn AC on condenser fan should come on but it doesn't. I am using scan gauge to check temperature. I saw temp around 200*f but fan didn't move. So where it went wrong? All connectors are plugged in.
I think new t-stat solved the problem because temp gets high but its comes down around 188-192*f. But now fans are driving me nuts..
Old Jan 14, 2010 | 11:50 PM
tmnhs81's Avatar
Some pics of the nasty stuff inside the t-stat..
And this is what I am dealing with. While car is moving temp doesn't come below this point..
Fan works but it only works around 202*+ F
Old Jan 15, 2010 | 12:36 AM
phee's Avatar
I got the Shifts
its supposed to kick in at a certain temp. maybe you should test to make sure all the connections are working. fans should kick in when thermostat opens
Old Jan 15, 2010 | 09:08 AM
NSXNEXT's Avatar
Replace the radiator fan switch.
Fool
Mar 10, 2016 08:42 PM
SinCityTLX
20
Oct 19, 2015 11:23 AM
Cgannotti
Sep 25, 2015 05:04 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
maharajamd
Console & Computer Gaming
Sep 24, 2015 03:31 PM
