Cl7/8/9
Old Jun 25, 2007 | 11:04 AM
TeinTSX's Avatar
Cl7/8/9
Not to sure where this thread should be, so sorry if it's in the wrong place.
I went to Kenstyle's home page to look at the kits for the TSX and I saw CL7/8/9... I'm new to the whole TSX thing, so I was wondering what the numbers meant.
Is it like different yr/models? I use to own a 300zx TT, and for the Z's they had codes like z31 (older 300zx), z32 (newer 300zx), z33 (350z)
Is this like the same idea?
Old Jun 25, 2007 | 12:30 PM
LuvMyTSX's Avatar
Chassis Code - ABA-CL7 | JDM Accord Euro R
Transmission - 6 Speed Manual Only | FF
Factory Length, Width & Height - 4.665M, 1.760M & 1.450M
Weight - 1,390KG
Engine Type - K20a DOHC i-VTEC 1,998CM³
Compression Ratio - 11.5
Fuel Tank Capacity - 65L
Max Horsepower - 162kW [220PS] @ 8,000RPMs
Max Torque - 206Nm [21.0KG/m] @ 6,000RPMs
Tyres - 215/45R17 87W
Chassis Code - DBA-CL7 | JDM Grade 20EL/20A
Transmission - 5 Speed Automatic & 6 Speed Manual | FF
20EL Grade Weight - 1,400KG | 1,410KG (S SRS) | 1,420KG (S SRS + Sunroof)
20A Grade Weight - 1,370KG | 1,380KG (S SRS) | 1,390KG (S SRS + Sunroof)
Compression Ratio - 9.8
Max Horsepower - 114kW [155PS] @ 6,000RPMs
Max Torque - 188Nm [19.2KG/m] @ 4,500RPMs
20EL Grade Tyres - 195/65R15 91H | Factory Option 205/55R16 89V
20A Grade Tyres - 195/65R15 91H
Chassis Code - ABA-CL8 | JDM Grade 20EL/20A
Transmission - 5 Speed Automatic & 6 Speed Manual | 4WD
Factory Length, Width & Height - 4.665M, 1.760M & 1.470M
20EL Grade Weight - 1,470KG | 1,480KG (S SRS) | 1,490KG (S SRS + Sunroof)
20A Grade Weight - 1,450KG | 1,460KG (S SRS) | 1,470KG (S SRS + Sunroof)
Fuel Tank Capacity - 60L
Max Horsepower - 112kW [152PS] @ 6,000RPMs
Max Torque - 186Nm [19.0KG/m] @ 4,500RPMs
Chassis Code - ABA-CL9 | Worldwide Grade
Weight - 1,440+10KG | 1,450+10KG (S SRS) | 1,460+10KG (S SRS + Sunroof)
Engine Type - K24a DOHC i-VTEC 2,354CM³
Compression Ratio - 10.5
Max Horsepower - 147kW [200PS] @ 6,800RPMs
Max Torque - 232Nm [23.7KG/m] @ 4,500RPMs
Tyres - 205/55R16 89V | Factory Option 225/45R17 90W
Old Jun 25, 2007 | 12:33 PM
LuvMyTSX's Avatar
BTW, the TSX is CL9 for the US.
This info was taken from another forum.
Old Jun 25, 2007 | 01:24 PM
shrykhar's Avatar
That's new to me ...
Old Jun 25, 2007 | 01:39 PM
LuvMyTSX's Avatar
I just copied and pasted it, didn't really look at it, but yeah, that's weird.
Old Jun 26, 2007 | 10:56 AM
TeinTSX's Avatar
Ahh okay, so basically I have a CL9...
Thanks for the info!
