civicdrivr's Z3 thread
I'd rather Morgan's avatars be on the creepy/strange side than the, "Dammit, I can't look at your posts without being turned on" side.
I could make that sound more suggestive...."Dammit, I can't look at your post without being turned on!"
Mods:440WHP 340WTQ - DynoJet 224
STOCK LONGBLOCK.
Accelerated Performance BRZ-400 Turbo Kit @ 20PSI
AEM Tru Boost Controller
Stock Header
Accelerated Performance catless turbo back exhaust
OMNI 4 BAR Map Sensor
DW65 Pump
DW900 Injectors
Exedy Clutch
IIRC they were running E85 as well.
Id say about $6k for a similar setup. I dont like their setup though. Its seems inefficient.
They use the stock header and put the turbo in the over pipe. The stock header is garbage. With a proper header and better plumbing throughout, they can make that power on less boost.
Less boost = less stress
Ease of fabrication, plus they were first to market.
Their kit is stupid expensive for what you get. $5k for the base kit, youll see about 280whp out of 8psi.
I think a kit with good scavenging and the proper turbo could hit that on 5psi. 300+ on 8. Thats just what I think though, we'll see what others come up with.
You can run a lot of power on stock internals, its all in the tuning and how the turbo kit is built. I dont see this car running 700whp like the S2k guys, but I think 4-500whp is perfectly reasonable on a stock block - even with the high compression. The direct injection really helps too.
Plus, these high power cars that are out there right now are shop cars. Theyre bumping up the boost to test their kits and the engine. Im fine with it, Id love to see when the motor decides to let go and after how many miles. That way I can set my goals accordingly. If I boost, I do not want to build the engine.
But......
I need money
That would require internals......not doing it.
Sweat my ass off this afternoon fixing the exhaust. Somehow, when SRT reinstalled the mid-pipe after replacing the resonator, they installed it clocked a bit too much. That caused the midpipe to pop out of the hanger right before the diff and pushed the rear section of the exhaust to the left. In doing so, the passenger side tip contacted the diffuser and melted it slightly
It took a bit of messing with it, but I managed to get it aligned again. It seems as though they welded it back up slightly crooked. We'll see if my fix sticks. If it doesnt, Ill be contacting them for a fix.
Also detailed the interior. I hate cloth seats. Theyre a pain in the ass to get lint free.
But I 303'd everything and vacuumed the interior/trunk so now its nice and clean. I was going to wash/wax it afterwards but a storm rolled through. The paint was too hot anyway, so Ill just wash it in the AM.
You shouldn't be allowed to post anything without pictures included. Even phone pics, uploaded to photobucket app would keep us from coming after you with pitchforks!
