Can you change a starter???
I can't...
my honda civic makes a horrrible noise when I crank it, its like a screeching/grinding noise and wont turn over
I'm assuming its the starter,....how do I replace it? is it straight forward? bold off bolt on??
is there anything I should particularly be aware of???
I can't...
From what I gather, it might be that your starter is loose. The gears on the starter are grinding with the gears on the flywheel, making the grinding noise. Get under the car and look to see that your starter isn't loose.
Should be very straightforward as others have mentioned, but take the time to disconnect the battery first.
Depending on where you purchase a new one (or reman), you can usually obtain a credit (or core) if you bring back the old one.
Terry
Terry
Just get a reman one from your favorite auto parts store. The quality of them seem to be a hit or miss, but they usually come with a lifetime warranty.
Some of them can be quite tough to access, so good luck.
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
