Calling all suspension set up gurus
Trolling Canuckistan
First off, I'm hoping I'm posting this in the right spot.
I have a Tein SS-P suspension in my car which allows for 16 different levels of dampening and rebound. My question is, what would be the best setting for winter driving (ie driving in snow). The car is running on 17" rims with a Dunlop Graspic snow tire.
I know the car is much more likely to hydroplane with the suspension set to a stiffer setting. I just haven't driven this car much in the snow, up until this year I have used a 97 Prelude as a winter beater, so this is my first winter with the Teins and Snow tires on the car and I'm looking to optimize my setup.
So, what do the Aziners with adjustable suspension set ups set their cars for in the winter? Does a firmer set up lead to terminal understeer (which I suspect) or does the extra body roll of a soft set up cause the car to plow straight when you wanted to turn?
Thanks in advance.
Thanks in advance.
Wow, no one knows about proper suspension dampening for the snow?
Well 2000TaffetaTL, it looks like we are on our own. We've got snow coming in tonight so I guess I'll just experiment and see what happens. My first instinct would be that softer (too a point) would be better. You might want to tune yours down a bit the next time you have snow (does it ever stop snowing in Denver?) and see how it feels.
I have mine at 12F/10R since last year it works very well all year long. You should never have it on the stiffest settings...there is no real advantage. Horrible ride quality and it doesn't "handle" better.
teh Senior Instigator
My car seems to hydroplane more when I'm set higher than 9. I haven't done any real scientific research on it but if it's raining hard, I'll adjust the fronts down to 7 and it seems to resolve the issue.
I SUPPOSE certain suspension settings could contribute to hydroplaning, I'd be blaming your tires for 99% of that.
For snow driving you want a slightly higher ride height if your town isnt plowing like it should. Otherwise just leave everything alone and keep a set of higher profile/narrower tires for the winter.
Lots of old american cars (Caddys especially) feel like they are doing fine on the road, until it starts to slip and you realize things have gone waaayy too far. On the other hand a car with a stiffer suspension helps you feel what the car is doing way earlier so you can avoid catastrophic failure.
Isn't it more likely to be that you FEEL like it is hydroplaning less?
FWIW, it's a CL-S 6MT.
A surfboard allows you to cut through the water like a tires groves do (hence why a thin short board is more maneuverable then a thick long board)
Worn out tires and summer tires are more likely to hydroplane because they don't have the depth or amount of groves in order to disperse the water around and through them.
the groves in this tire (or syphons) allow it to cut through and disperse water
where as the groves in this tire are built for dry traction, they aren't as deep and aren't focused on siphoning out/ dispersing water
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
IndycarFaster
Sep 11, 2015 02:52 PM
braveheart
Sep 7, 2015 08:12 AM
