Building a 2000 HP 4G63
Old Jan 7, 2011 | 12:43 PM
ghttf's Avatar
Saw this on farm of minds. Not finished yet...
So, getting 700whp/L from 2.0L @ 8500rpm is no small feat, but what do you need if you get bored and want to shoot for 2000 hp?
<br />
<br />
Cast Garrett compressor wheels (right) tend to come apart above 50 psi. CNC billet aluminum wheels (middle) are stronger, but why not be different and use your own CNC billet titanium (left) compressor?<br />
<img src="http://img43.imageshack.us/img43/4817/compwheels.jpg" border="0" alt="" /><br />
<br />
<br />
<br />
You'll need a turbo big enough for the job, which in this case is a 108mm twinscroll T4 turbo, with custom quad ball bearing CHRA and 100psi capability.<br />
<img src="http://img97.imageshack.us/img97/5795/gt47killer.jpg" border="0" alt="" /><br />
<br />
<img src="http://img541.imageshack.us/img541/2928/turbo3.jpg" border="0" alt="" /><br />
<br />
<img src="http://img232.imageshack.us/img232/3429/2000hpturbo.jpg" border="0" alt="" /><br />
<br />
<br />
<br />
To get enough airflow at 12,000rpm(!) to get the job done, you'll need a skillfully ported head, complete with titanium valves and copper-beryllium valve seats:<br />
<img src="http://img686.imageshack.us/img686/8733/cylinder5.jpg" border="0" alt="" /><br />
<br />
<img src="http://img5.imageshack.us/img5/3448/cylinder.jpg" border="0" alt="" /><br />
<br />
<img src="http://img94.imageshack.us/img94/4258/cylinder1.jpg" border="0" alt="" /><br />
<br />
<br />
<br />
And you're going to need a set of camshafts to handle the rpm and withstand tremendous ramp pressures, so why not a set of hollow titanium billets with DLC at only 234 grams each?<br />
<br />
<img src="http://img820.imageshack.us/img820/1853/titaniumcams.jpg" border="0" alt="" /><br />
<br />
<img src="http://img13.imageshack.us/img13/1205/titaniumcams1.jpg" border="0" alt="" /><br />
<br />
<img src="http://img156.imageshack.us/img156/3443/titaniumcams2.jpg" border="0" alt="" /><br />
<br />
<br />
<br />
And since there is no aftermarket rod up to the task, just ask for a set of billet mmcs-titanium connecting rods at 286g each. Rod/Stroke ratio is 2.07:<br />
<br />
<img src="http://img651.imageshack.us/img651/1227/titanium1.jpg" border="0" alt="" /><br />
<br />
<img src="http://img707.imageshack.us/img707/3097/titanium2.jpg" border="0" alt="" /><br />
<br />
<br />
For pistons, a set of custom beryllium pistons with DLC fits the bill, and since methanol is the fuel, 13:1 SCR is fine:<br />
<br />
<img src="http://img822.imageshack.us/img822/5373/pistonnew3.jpg" border="0" alt="" /><br />
<br />
<img src="http://img9.imageshack.us/img9/966/pistonnew2.jpg" border="0" alt="" /><br />
<br />
<br />
<br />
A strong piston pin is needed as well:<br />
<br />
<img src="http://img517.imageshack.us/img517/7840/pincustom.jpg" border="0" alt="" /><br />
<br />
<br />
<br />
<br />
Toss in a custom titanium billet crank:<br />
<br />
<img src="http://img686.imageshack.us/img686/1179/crankti.jpg" border="0" alt="" /><br />
<br />
<br />
<br />
A set of 9000cc/min injectors:<br />
<br />
<img src="http://img43.imageshack.us/img43/3491/850lbsinj.jpg" border="0" alt="" /><br />
<br />
<br />
And since a factory 4G63 block probably wouldn't hold up, just CNC machine your own from billet aluminum:<br />
<br />
<img src="http://img171.imageshack.us/img171/1241/billet1.jpg" border="0" alt="" /><br />
<br />
<img src="http://img15.imageshack.us/img15/2074/billet2.jpg" border="0" alt="" /><br />
<br />
<br />
No head gasket is used:<br />
<br />
<img src="http://img163.imageshack.us/img163/6619/2000hpengine2.jpg" border="0" alt="" /><br />
<br />
<br />
And to put all that power to the gearbox, one needs a suitable multiplate clutch:<br />
<br />
<img src="http://img63.imageshack.us/img63/3985/clutch1.jpg" border="0" alt="" /><br />
<br />
<br />
Yes, it is smaller than a cam gear:<br />
<br />
<img src="http://img156.imageshack.us/img156/8171/clutch3f.jpg" border="0" alt="" /><br />
<br />
<img src="http://img714.imageshack.us/img714/9788/clutch4s.jpg" border="0" alt="" /><br />
<br />
<br />
An example of very efficient turbo manifold design from one of their recent projects:<br />
<br />
<img src="http://img824.imageshack.us/img824/7996/project2.jpg" border="0" alt="" /><br />
<br />
<img src="http://img820.imageshack.us/img820/8940/project1.jpg" border="0" alt="" /><br />
<br />
<br />
And last but not least, a dynosheet from this car, running 'only' 48psi and hydraulic cams:<br />
<br />
<img src="http://img156.imageshack.us/img156/2001/evo81523hp.jpg" border="0" alt="" /></div>
http://forums.evolutionm.net/evo-dyn...ne-2007-a.html
Old Jan 7, 2011 | 12:56 PM
myron's Avatar
I've seen this a couple of days ago. Not sure if it was on this forum or not. Fucking awesome tho
Old Jan 7, 2011 | 12:57 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
That sucker would hand a Viper its ass. Wow.
Old Jan 7, 2011 | 01:07 PM
CanopyFlyer's Avatar
I Skydive, Therefore I Am
That sucker would hand ANYTHING its ass. Wow.
Fixed.
Old Jan 7, 2011 | 01:14 PM
Brandon24pdx's Avatar
Por Favor?
Oh I think I see what's happening here
Old Jan 7, 2011 | 01:23 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Old Jan 7, 2011 | 02:22 PM
Stapler's Avatar
I don't know much about turbo's but I see 3 exhausts. Are the two small ones for Blow off Valves?
Old Jan 7, 2011 | 04:10 PM
knight rider's Avatar
Rooting for Acura
Okay so what do they do to the frame, brakes, suspension, wheels and tires to make anything mounted on top of this monster drivable?
Old Jan 7, 2011 | 04:43 PM
rondog's Avatar
Former Sponsor
Thats insane, imagine that in a daily driver.
Old Jan 7, 2011 | 04:49 PM
AMUA6's Avatar
ScoobyZINE
Fook mi
Old Jan 7, 2011 | 05:06 PM
achenator's Avatar
Wow, lose traction much?
Old Jan 7, 2011 | 05:14 PM
Aman's Avatar
Your Friendly Canadian
Holy shitake mushrooms
EDIT: Check out that dynograph? Turbo lag much? Some cars here probably have more low-end grunt than this bad boy.
Old Jan 7, 2011 | 07:54 PM
fsttyms1's Avatar
That is impressive, but useless. Though Ive seen similar builds from a duramax (stock block though) running just shy of 100psi. Hp is similar to that and tq is double the hp shown.
Old Jan 7, 2011 | 08:11 PM
friesm2000's Avatar
B A N N E D
FUCK
but still a good example though, to making more power (just on the extreme side though)
Old Jan 7, 2011 | 08:30 PM
05TLdcc's Avatar
Coal
this. every freaking component has to be upgraded to handle this kind of power. its insane.
Old Jan 7, 2011 | 09:13 PM
v6cord2k5's Avatar
seizure force field!
I wouldn't mind 200hp at 4k RPM...
Old Jan 7, 2011 | 09:56 PM
Aman's Avatar
^ That can't be too far off what you're making now though, can it?
Old Jan 7, 2011 | 10:04 PM
StreetKA's Avatar
:Unfuckinbeliveble:
Old Jan 7, 2011 | 10:31 PM
achenator's Avatar
This is amazing. My buddy has an 08 350z with 723 rwhp and I have seen what he has gone through to make that somewhat reliable. ($$$$). This is a whole different level.
Old Jan 7, 2011 | 10:35 PM
v6cord2k5's Avatar
Are there videos of this thing in action?
I'd be lucky to make that at 6.5k...
Old Jan 7, 2011 | 11:26 PM
CLtotheTL32's Avatar
Originally Posted by AMUA6
Fook mi
No, fook yu!
That's an amazing build. I wonder how long it took to design and get everything made.
Old Jan 8, 2011 | 12:23 AM
Aman's Avatar
Really? 2005 Accord V6s are rated at 240 hp at something like 6k rpm, right?
At 3750, this car is making only 100 horsepower. Is an Accord making less than that at that rpm?
Either way, the feeling of hitting boost in this thing must be biblical.
Old Jan 8, 2011 | 12:34 AM
v6cord2k5's Avatar
240bhp... Driveterrain losses and such would probably rob me that measly 40. This race Evo is probably a whole ton lighter and the dynapack measures hp at the hub. Not to mention all the light materials probably mean this thing revs oh so freely.
Old Jan 8, 2011 | 12:36 AM
Aman's Avatar
Forgot about the bhp vs. whp thing. Or hhp...
Old Jan 8, 2011 | 01:14 AM
SpiderX1016's Avatar
Those parts are pretty. Too bad you can't see the valves once it's closed up but they're so nice.
Old Jan 8, 2011 | 12:09 PM
TheMirror's Avatar
Disinformation Terminator
Old Jan 8, 2011 | 01:36 PM
Crazy Bimmer's Avatar
turbo lag
Old Jan 8, 2011 | 02:13 PM
Costco's Avatar
Jesus, I've never even heard of copper-beryllium seats
Everything looks like freaking overkill for a gas-powered automobile engine. The rods look insane, machining a block from a block of billet aluminum
I've seen big turbos before, but his hand in the pictures with the housing and the compressor wheel...... holy crap.
Streetability and low end power don't really mean crap, since there's probably a 0.00% chance, give or take that this car will see the street.
Old Jan 8, 2011 | 03:44 PM
Por Favor?
Nah it's just a 1/4 drag racer. Hell it doesn't even run on gasoline.
Old Jan 8, 2011 | 03:47 PM
Por Favor?
Wastegates. One apparently wasn't enough to bypass enough exhaust to keep the turbo from spinning out of control.
Old Jan 8, 2011 | 05:29 PM
friesm2000's Avatar
B A N N E D
or more like, it is a twin scroll turbo, which means it has two different inlets to the turbine side, and they wanted to maintain them separate, so they had to put on two wastegates in order to do that
Old Jan 8, 2011 | 06:54 PM
Aman's Avatar
Or maybe they're just cool like that
Why no head gasket?
Old Jan 8, 2011 | 09:15 PM
friesm2000's Avatar
B A N N E D
Why no head gasket?
first i see no coolant jackets in the new block, probably because they would compromise the strength of the block too much (and even then it hardly runs more then ten seconds at a time probably); so no need to keep water contained
second, you probably cannot find one strong enough to withstand the forces inside the cylinders; so to get the best seal, you just get two perfectly flat surfaces (even then i think with the cylinder cast iron sleeves, it will create a higher point, and compress the aluminum in the head some, thous creating a "seal", which is good enough for the time needed (and to compensate for any "leakage", they just bump up the boost some)
Old Jan 8, 2011 | 09:41 PM
S14 n Tsx's Avatar
mmmmmm....
holy batman..
Old Jan 9, 2011 | 12:19 AM
jayhawk815's Avatar
And impossible to control. I've never seen a hp curve quite like this on a gasoline engine intended for automobile usage. It has a 300% increase in hp from 5500-6500 rpm. Absolute absurdity.
Old Jan 9, 2011 | 05:25 AM
speedemon90's Avatar
God damn, just looking at that dino is intense. First off, there is an immense amount of turbo lag, but then again he has freaking huge ass turbos. I bet this spins all the way through 4th. Driving that think must have been scary on the dyno once the turbos kicked in, even though you know you are strapped in.
Old Jan 9, 2011 | 06:26 PM
OperationDarkie's Avatar
Ultra Negro
Nah I don't think it is a twin scroll, it is just because he has so much pressure he ran 2 50 psi rated wastegates, at least that is what it looks like to me.
Old Jan 9, 2011 | 06:31 PM
LasVegasTL's Avatar
Unleash the Krakken!!!!
Old Jan 9, 2011 | 06:44 PM
Aman's Avatar
The second paragraph makes sense, but are you saying this guy's running with no type of cooling at all?
But the builder makes it clear that this motor is just here to make lots and lots of power, nothing else.
Old Jan 9, 2011 | 06:45 PM
friesm2000's Avatar
B A N N E D
it is indeed a twinscroll TYVM (3rd picture down in original post)
but for quick referance:
