View Poll Results: which is the better beater?
Voters: 68. You may not vote on this poll
which is a better beater car? (please vote)
A 1995 Nissan Maxima with 104K miles on the clock, for $1200 or a 1998 Nissan Altima with 81K miles on it for $2500?
I am confused...
ediit - i should mention that the maxima has a crack in the front bumper, and a dent in the rear one, and will also need new brakes but it is otherwise mechanically sound.
the altima just has the normal wear and tear of a 10 yr old car.
If you pick none of the above, then please recommend one in the same price range.
I am confused...
crack in the front bumper.... dent in the rear..... that Maxima is a PERFECT beater. No lame timing belt to worry about, and a great price. And even if you don't do it yourself a brake job isn't much. Just my opinion but a 95 Maxima is a better car than that year Altima.
If mechanically both are equally sound then I would go with the Maxima.. Dents and cracks in the bumper plastic should not be withholding factor for a car at the price point that you are looking at.
skaiiz tha limit
I chose the 98 altima. Just because its newer, chances are more reliable. If you chose the 95 it might cost more in the end to fix than to just get the 98.
I ended up buying the Maxima. It had more miles on the clock than I anticipated (135K), and it has this issue of where when the car is cold and I put on the heat, there is a gas smell. I was told it's because of the rubber hose from the fuel injector contracts in the cold and it should be a cheap fix (or so I hope). It also has more body damage than I first realized, but I don't really care about that since it's a beater. Other than that, the car seems fine. The engine purrs. It has an aftermarket Pioneer stereo, it just passed inspection yesterday (at the seller's expense - good for 1 year), and I got it for $1250 cash.
As I mentioned above; I couldn't find a cheaper one on a nationwide autotrader/cars.com search for a similar vehicle.
Not a bad deal. Hell, I sold my 95 Maxima with close to 200K for $3000. When I sold it, the CEL was on because of a bad Knock Sensor, a dead starter and battery, dented fender and it needed brakes and tires.
$1250 is nothing for that car.
I voted either...both are good cars.
My parents have had Altima's since 1994 and never had a problem with any of them. Of course they are leased, so they both get new ones every three years (about a year apart b/c of the timing), but never had a problem with any of them over the last 14 years...
The Box
I voted Maxima; that is a solid car. I've seen many with well over 200K miles on them. That is a very good price for it. My friend just sold a 97 with 140K in pretty rough shape for 3200..
