Alignment Issue
Old Jul 6, 2008 | 04:44 PM
  #41
Scrib's Avatar
Administrator Alumnus
Originally Posted by SodaLuvr
I talked to him again and he said that it is evident from the excessive positive camber on one side and the excessive negative camber on the other, marked by the extreme cross camber.
And he would fix it, how???
Old Jul 6, 2008 | 04:47 PM
  #42
SodaLuvr's Avatar
I'll ask him later tonight.
In the meantime, I found this:
Uneven camber side-to-side. Too much cross-camber can make a vehicle pull or lead towards the side that has the most (positive) camber or away from the side that has the least (negative) camber. The underlying cause may be a bent strut or mislocated strut tower, a bent spindle, collapsed control arm bushing, weak or broken spring, or a shifted crossmember or engine cradle. Check SAI and the included angle to see if these are in or out of specs to diagnose the problem. Also check ride height. Correct by replacing worn or damaged parts, correcting location of strut tower, repositioning engine cradle, and/or reducing cross-camber to half a degree or less by readjusting camber to specifications.
http://www.aa1car.com/library/steerpul.htm
Old Jul 6, 2008 | 07:00 PM
  #43
Will Y.'s Avatar
Registered but harmless
I think Scrib already learned it was a bad left rear knuckle assembly?
If that's the case, would the engine cradle still be an issue?
Old Jul 6, 2008 | 07:43 PM
  #44
Scrib's Avatar
No, no... They had the wrong VIN. So I have no idea what is wrong.
Old Jul 7, 2008 | 08:48 AM
  #45
Scrib's Avatar
lol
So I called the dealer I am to take the car to tomorrow and spoke with the service manager. Told him my story, etc.
He was questioning why I would even bring the car to them if they're going to determine the same thing that the Honda dealer did. He told me to take it straight to a frame shop.
So he's going to speak with Acura and see what's up.
I give up.
Old Jul 11, 2008 | 11:21 AM
  #46
Scrib's Avatar
fixed
That is all.
Old Jul 11, 2008 | 11:53 AM
  #47
Infamous425's Avatar
fap fap fap
so what car did you get to replace it?
Old Jul 11, 2008 | 11:56 AM
  #48
Scrib's Avatar
They fixed the car.
Old Jul 11, 2008 | 11:59 AM
  #49
fap fap fap
oh, still stuck with that thing
Old Jul 11, 2008 | 12:03 PM
  #50
Will Y.'s Avatar
They fixed the car.
Just curious: HOW did dealer fix it- what did it replace, if anything?
Old Jul 11, 2008 | 12:16 PM
  #51
charliemike's Avatar
Fahrvergnügen'd
They fixed the car.
By giving you a new one?
Old Jul 11, 2008 | 12:23 PM
  #52
Trackruner228's Avatar
They fixed the car.
cool
Old Jul 11, 2008 | 12:24 PM
  #53
Street Spirit's Avatar
Was it something so minor or easy that it's just too embarrassing to write or something? Fixed..............and?
I bet it's a relief. Who did the work?
Old Jul 11, 2008 | 12:45 PM
  #54
Crazy Bimmer's Avatar
Hopefully its not something like the tire pressure was too low.
Old Jul 11, 2008 | 01:35 PM
  #55
GreenMonster's Avatar
They fixed the car.
Details ?? Just re-aligned ??
Old Jul 11, 2008 | 02:00 PM
  #56
mclarenf3387's Avatar
If it was, then he can blame the people doing the alignment, thats one of the first things you do before putting the car on the rack.
Old Jul 11, 2008 | 09:10 PM
  #57
Scrib's Avatar
To make a long story short, the dealer I took the car to stepped up bigtime and took care of the issue.
Evidently, there are some adjustments that can be made to eliminate the issue I was having. Funny that my "former" dealer didn't even acknowledge this. They stated that this is a well known issue on the earlier model year TSXs and they have seen the issue and thus knew how to fix it.
They had it on the rack three times and got it dialed in the third time. The car drives like it's brand new. No push, no pull, perfectly aligned steering wheel.
I must say I'm awfully disappointed in my dealership and I am extremely happy and satisfied this dealer went out of their way and resolved this matter. Extremely professional and they deeply regretted me having to go through what I did.
Old Jul 11, 2008 | 09:18 PM
  #58
Weird... But I guess the level of service differs from dealer to dealer... It's amazing that the first dealer made you just thru hoops, and the last dealer handled it like it was a run of the mill issue
Old Jul 11, 2008 | 09:24 PM
  #59
Scrib's Avatar
It was night and day. This was the dealer I bought my CL-S from and didn't go back to them for the TSX just because of the nature of the deal I got when I dumped my G35.
I'll gladly drive the 15 additional miles for premium customer service.
Old Jul 11, 2008 | 09:52 PM
  #60
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
Sucks they didn't give you a print out from the first alignment(from the second dealership), this is clearly the printout from the final, the "before" on the new printout doesn't make sense based on the original you posted. In any case I am much happier with the front toe in the most recent alignment, I wish the rear toe was a little more even, but if the car feels right, a little tire wear is a small price to pay.
Old Jul 11, 2008 | 11:12 PM
  #61
Scrib's Avatar
Yea, I didn't realize they didn't give me the first two... They did mention that they could not reproduce the numbers the Honda dealer provided and questioned if their alignment rack was off.
Old Jul 12, 2008 | 03:09 AM
  #62
The Dougler's Avatar
Unofficial Goat
My bro has similar issues with his TL-S, do you know what exactly they did to correct the alignment? He's had like 3 or 4 alignments and it still pulls. They keep giving him alignments free, but it would be nice to find the root cause.
Old Jul 12, 2008 | 05:55 AM
  #63
dallison's Avatar
registered pw
looks like you found a place to buy your next car. glad the issue was fixed
Old Jul 12, 2008 | 09:14 AM
  #64
Scrib's Avatar
There are evidently adjustments to bolts, etc that can be made on the frame. It took them three times to get it, from what I understand.
But it drives true, now.
Old Jul 12, 2008 | 10:27 AM
  #65
Gilgamesh's Avatar
So it would seem that they corrected the issue without a camber kit then? Like the car has some way to adjust all alignment settings to spec, without additional expense, if the suspension if unmodified?
Hmm. Sounds about right.
Old Jul 12, 2008 | 10:32 AM
  #66
Scrib's Avatar
Yup.
Old Jul 12, 2008 | 12:40 PM
  #67
260 HP's Avatar
Sounds like they shifted the subframe, no?
Old Jul 12, 2008 | 02:07 PM
  #68
Scrib's Avatar
Could have... But I swear I heard the rep said the word "bolts".
Old Jul 12, 2008 | 02:41 PM
  #69
Gilgamesh's Avatar
Didn't someone say that it could not be done in stock form. Right here in this thread I think.
Old Jul 12, 2008 | 08:18 PM
  #70
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
You do realize that in many cases camber kits are glorified bolts, right? Without seeing the before and/or talking directly to the tech that performed the alignment all we are doing is guessing. There is a very easy way to adjust rear camber with out replacing any parts, on the front of a TSX it is not so easy. I am very familiar with the alignment rack used, based on the second printout I know it was a Hunter, there is a way to make any car spot on with a Hunter rack. Unless Scrib was at the dealership for north of 3 hours, I don't think they "shifted" the subframe, they had it in and out of the alignment bay 3 times, they wouldn't have had the time to do that. My guess, they dialed in the toe correctly, which was the steering wheel alignment problem and tweaked the rack to get the printout right, the few attempts were dialing in the toe, which is not uncommon and takes very little time. I've performed thousands of alignments when I worked on cars and know the "tricks." At the end of the day, what difference does it make? The car is aligned, the customer is happy and the camber problem it had on the front wouldn't make a noticeable impact on tire wear.
Old Jul 12, 2008 | 08:32 PM
  #71
You can change the ranges on the Hunter racks to get everything in the green.
Old Jul 12, 2008 | 09:23 PM
  #72
neuronbob's Avatar
Glad the problem is solved!
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Zonian22
Nov 14, 2015 01:20 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Sep 14, 2015 10:09 PM
Zonian22
Sep 2, 2015 08:19 AM
