Alignment Issue
Administrator Alumnus
Alignment Issue
So I've been having alignment issues with my TSX since day one. Had an alignment done at 10K miles and they paid for it. Now at 22K, the same issues still exist.
The Acura dealer recommended another alignment, even though, they never even drove the car when they were to inspect it. (wtf!) And they don't have an alignment rack at their shop, it's all outsourced.
So I took it to the local Honda dealer as they have always done good service work. I took it on the dealer's good word that I needed an alignment. And sure enough, I did.
However, the Cross Camber is also all fucked up and something that the dealer says isn't a warranty item and are sticking me with it. They say it probably happened by hitting a pot hole, blah blah blah... Jerks.
Anyone familiar with Cross Camber issues and how to fix? I guess it has to go to an autobody shop or something similar. Can pot holes knock it out that far??? Tire wear is very good and there is no uneven wear.
I assume the car is bone stock, right?
The front camber issue can be fixed (but rather expensively, if it's not under warranty) by shifting the front subframe a little to the left. This is a warranty issue, unless they can proof and show you the marks or signs of you hitting anything on the suspension or frame. If the front end chassis looks clean, their claim just doesn't hold water.
Do you know if the car hasn't had any accident whatsoever? Have you taken a look under the car?
Yep, bone stock. Acura will NOT warranty this. Both my dealership and another I called, both said this is a wear and tear item probably because I hit a pothole. The car has never been in a wreck. I even asked and looked myself earlier today when the car was on the rack. Nothing is bent, etc. Is it possible to get the camber out of whack by hitting a pothole and not damaging anything else?
I have since learned about the subframe adjustment and it doesn't sound like a pleasant wallet experience.
Fucking infuriating.
dɐɹɔ ǝɥʇ ʇɐɥʍ
When I had a TSX my car had the same problem, I've performed thousands of alignments over the years and would check mine some what often. Short of putting in camber kits in the front and rear there is no safe way to correct it. Cross camber is a none issue, it is simply the difference between both front cambers, in a severe case it will cause a pull, as long as the tires are wearing well its not worth addressing. As for the rear, my car had the same problem on one side, the only thing I could come up with is that when it was transported they tied it down with one of the multi-links in the rear suspension and it got tweaked, to the naked eye it would be impossible to tell which one.
If your car has a pull right now, which it may, it is due to the front toe, even though the total toe measures perfect, it is not added like cross camber is. The way your car is set up right now is one wheel is toed in, the other is toed out, that is the recipe for a off center steering wheel. On the TSX I found the best feeling suspension set up was rear wheels toed in just under maximum spec for toe and and the fronts toed out just under maximum spec, this wears tires a bit rapidly and will make any camber problems more noticeable, but the car will feel phenomenal. I should also mention short of a comptech RSB and really good tires, my suspension was otherwise bone stock.
It is definitely a possibility to throw anything, camber, caster, out of spec, but it would have to be a big-@$$ pothole.
If you're stuck, call Acura and request assistance. Ask for someone from your district to look at your car personally before making any decision.
Actually, a good alignment shop or body shop can shift the subframe for maybe less than what your incompetent dealers charge you.
Eric, anything can do it. I got hit in a parking lot when I had the G, guy was pulling in, and going very slow (I'm guessing by the body damage) His bumper got my wheel, and took the alignment out of whack. I replaced every cheap part I could and it would still miss spec. I stopped at the spindle and control arms, as it was getting expensive.
Try a body shop that can check the frame for straightness and then work down the suspension from there, if you have already replaced all of the cheap parts. Or just sell it like I did with mine. Good luck.
I would call acura and talk to some one there. Explain the alignment issue since day one and acura outsourcing it and never fixing the problem. See if they can get it fixed for you
dɐɹɔ ǝɥʇ ʇɐɥʍ
You guys are making this too complicated, it's not far out of spec, the problem is there is no camber adjustment from the factory the fix are camber kits for the front and rear. It would be cheaper then even checking the frame for straightness, with how close it is to being in spec it just needs a little tweaking and it will be spot on. If you are experiencing poor tire wear or the steering wheel is not level then get the cam kits, other wise live with it, it's not a perfect world and this is a very minor problem. And like I said in my first post, if the steering wheel isn't level chances are high it is the front toe that is causing the problem. TSX's have very minimal available adjustments from the factory, its a toe and go alignment, nothing is wrong with the car.
Well, whatever... I'm over this. Considering what is entailed to fix the problem, I'd think it'd take a pretty serious jolt to force it out of spec, no matter how far out of spec it is.
And iTimmy, I hear what you're saying, but driving this car is a chore as it tracks all over the road regardless of road grade, etc. It's really fucking annoying.
I knocked my alignment off a couple times with pot holes in NY. It sucks. I did my first one at the dealership. After that I just took it some place private and had better success that way.
registered pw
sounds like a quality issue that acura has with this vehicle. i don't think shifting the frame should be an option on a car this new. I really don't think hitting 1000 potholes would damage the frame unless you bottom oput each time.
You really need to take this to the next level
My shop couldnt align my car properly either so they installed a camber kit. I was uber lazy about the whole thing because frankly, I just dont get it. Paid them $150 and the realigned it for free.
dɐɹɔ ǝɥʇ ʇɐɥʍ
Originally Posted by synth19
I see only one option at this point, trade in the car for an NSX.
dɐɹɔ ǝɥʇ ʇɐɥʍ
front of car
l--------l
back of car
Corporate just called...
Acura: So did you file a police report after the accident?
Me: accident?
Acura: The accident where the left rear knuckle needed to be replaced.
Me: left rear knuckle? Are you sure you are calling me over the right case? *Gives case number*
Acura: I need to call the dealership back. This is the information they gave me for your VIN.
What in the holy fuck? My car has never been in an accident. That is some kind of a mistake.
Me: accident?
dɐɹɔ ǝɥʇ ʇɐɥʍ
Me: accident?
Me: accident?
So since my dealership doesn't have an alignment rack and I took it to the Honda dealer, I have to take it to an Acura dealership with an alignment rack to diagnose. Acura won't honor the readout from the Honda dealer.
So I have to take the car in and pay the alignment fee; $129.95 and then see if Acura will warranty the work???!!?? So because my dealer doesn't have an alignment rack, I'm potentially out another $130 as there is still no guarantee that the work will be fixed under warranty.
Does this make any sense to anyone?
And you have to pay for an alignment to see if Acura will warranty the car? That makes absolutely no sense.
Makes perfect sense. Nobody wants to take care of their customers anymore.
dɐɹɔ ǝɥʇ ʇɐɥʍ
Be Strong AND Courageous!
Bad from the factory, now to you, then to the next person if you trade your car... new cars are starting to be worse to repair than just having a older car that needs a tweak now and then... nothing cost less than a cool thousand to fix now a days... I am so over Acura right now...
If I had a problem with a car and dealer, the dealer, of all people, said it couldn't be fixed more or less, I trade it in. The trade in hit might compare with the ultimate repair bill afterall. I wouldn't avoid Honda on account of this though. Don't let the repair dept. speak for the whole brand.
I showed a friend of mine who's an alignment this thread. He believes that this is a classic case of the engine cradle being misaligned at the factory, and that this is a clearly a factory defect.
Good luck.
Good luck.
How does one determine that is the issue simply by reviewing an alignment sheet?
