Alignment Gurus
Old Jun 4, 2009 | 08:33 PM
v6cord2k5's Avatar
seizure force field!
Alignment Gurus
Trying to decipher what all this stuff means...
Left Front
Camber - Actual = .1, Before = .1, Specified Range = -.8 to .8
Caster - Actual = 2.1, Before = 2.1, Specified = 2.5, Range = 4.0
Right Front
Caster - Actual = 2.7, Before = 2.7, Specified = 2.5, Range = 4.0
Front
Cross Camber - Actual = .0, Before = .0, Specified Range = -.8 to .8
Cross Caster - Actual = -.5, Before = -.5, Specified Range = --- to ---
Total Toe - Actual = .05, Before = .15, Specified Range = -.16 to .16
Left Rear
Camber - Actual = -1.2, Before = -1.2, Specified Range = -1.5 to -.5
Toe - Actual = .08, Before = .1, Specified Range = .0 to .16
Right Rear
Camber - Actual = -.6, Before = -.8, Specified Range = -1.5 to -.5
Toe - Actual = .1, Before = .48, Specified Range = .0 to .16
Rear
Total Toe - Actual = .17, Before = .58, Specified Range = .0 to .32
Thrust Angle - Actual = -.01, Before -.19, Specified Range --- to ---
The reason I'm posting this is because I thought my alignment was all out of whack because the front tires got worn badly/quickly. The guy said the alignment wasn't that bad before but that he made some adjustments. I noticed there are some differences between left and right in the "Actual". Should I be concerned?
Thanks for any help.
Old Jun 4, 2009 | 08:57 PM
OLD_HATCH's Avatar
There is no individual toe readouts for the left and right front tires?
Thats probably what caused your wear.
Is it on the sheet you got?
Old Jun 4, 2009 | 10:25 PM
v6cord2k5's Avatar
I somehow forgot to list them:
Left front toe - Actual = .02, Before = .08, Specified range = -.08 to .08
Right front toe - Actual = .04, Before = .07, Specified range =-.08 to .08
Also, car is a 2005 Honda Accord EXV6.
Old Jun 4, 2009 | 10:40 PM
Costco's Avatar
I wouldn't worry about those angles post-alignment. They look good to me. You want at most a half degree (.5) of variance between left-right for the common alignment angles, but caster is an exception. He probably set it that way to compensate for road crown.... that way your steering wheel stays straight and true. Caster isn't a tire wear angle unless its set to the extreme, so I wouldn't worry about it.
I remember hearing about a problem with some newer Hondas, specifically the non-Si Civic coupe in which the rear (or was it front?) tires were worn really quickly even though alignment angles were within factory spec. I think it was because of the factory control arms or something.... but I haven't heard of an issue with the Accords.
Old Jun 4, 2009 | 11:24 PM
v6cord2k5's Avatar
My first set of tires wore perfectly even. My brother hit a curb and blew the left front when they needed replacing. I installed the second set and before I knew it the fronts wore badly so I just let it go so I could replace the front pair instead of all four later.
What threw me off is that the guy said the alignment wasn't way off so I wanted to make sure the specs I have now were fine because I noticed the different degrees on left/right, but not much difference between actual/before.
Old Jun 5, 2009 | 08:06 AM
OLD_HATCH's Avatar
Did the tires wear out on the outside edges first?
Old Jun 5, 2009 | 09:50 AM
Dicorp's Avatar
When you bro hit a curb, he knocked the tie rod loose, which in turn led to misalinged toe that ate up your tires. get your tierods checked out/replaced, then do alignment again.
Old Jun 5, 2009 | 12:40 PM
v6cord2k5's Avatar
^ I'll check it out.
Yes, inside edges first.
Old Jun 5, 2009 | 12:51 PM
fsttyms1's Avatar
Was the Toe + or - out before? This doesnt show
Old Jun 5, 2009 | 04:23 PM
v6cord2k5's Avatar
If it was - I assume I would have a "-" on my sheet.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Zonian22
Nov 14, 2015 01:20 PM
TxRzrBk
Sep 17, 2015 01:07 PM
