5w20 put in by mistake
Old May 11, 2016 | 05:53 PM
calgary2800's Avatar
Anyone else put in 5w-20 when the car calls for 5w-30? Not a deal big or not? I live in Seattle, does not get too hot probably 5-7 days of 90 degree weather in summer and that is it.
Old May 11, 2016 | 06:04 PM
I doubt it'll matter for the cube. If you had an M5 I'd tell you to drain and refill.
Old May 11, 2016 | 06:51 PM
TLDude876's Avatar
Chapter Leader (Houston)
no big deal
Old May 12, 2016 | 08:01 AM
I think my Civic calls for 5W-20 & I've gone the other way & used 5W-30 when 20 wasn't available.
On an economy car, I doubt there is a significant issue with it.
Old May 12, 2016 | 08:12 AM
you're fine!!
Old May 12, 2016 | 10:02 AM
TacoBello's Avatar
it's fine to go to a thicker oil... going to a thinner oil could have consequences.
If you're oil pressure light doesn't come on, or doesn't stay on for longer than normal when you start the car, you should be okay...
I also assume this happened in your Cube, and I assume you don't rev the crap out of the engine and drive it like it was stolen. If you're driving around normally, that should also help keep you safe.
Old May 12, 2016 | 10:53 AM
dallison's Avatar
registered pw
Old May 12, 2016 | 02:41 PM
wackjum's Avatar
He went to a thinner oil. The specs called for 5w-30 and he used 5w-20. At operating temperature, his oil will thin out to a 20 weight viscosity oil which is thinner than 30 weight.
But either way, it should be ok. I've heard that around the world, Honda specifies 5w-30 for their engines but then specifies 5w-20 for the US for that slight edge in fuel economy. So the two weights seem almost nearly interchangeable.
Old May 12, 2016 | 06:46 PM
csmeance's Avatar
The crazy part is that even though weights should be 20 or 30, some oils tend to be towards the lighter side of their designation and some tend to be heavier.
I wouldn't run the oil as long as you normally would but it should be fine without an issue. Verify that there isn't any oil consumption after 2K miles to be on the safe side.
Old May 13, 2016 | 11:43 AM
fsttyms1's Avatar
Only reason honda went to the 5w20 was for cafe standards. You are fine with that oil in it (unless you consume oil normally)
Old May 13, 2016 | 12:58 PM
Chief F1 Fan's Avatar
then take out the 5W/20 on purpose.
Old May 13, 2016 | 01:50 PM
juniorbean's Avatar
OP
Old May 13, 2016 | 01:54 PM
TacoBello's Avatar
that's exactly what I was saying thicker is ok. thinner, generally not. depends on driving conditions. I really wouldn't sweat about putting it in though, as long as there are no oil pressure lights turning on.
Old May 13, 2016 | 02:16 PM
TLDude876's Avatar
I use to run 20w in the winters and 30w in the summers
Old May 13, 2016 | 05:35 PM
wackjum's Avatar
I thought you meant you're fine because running thicker is fine.
I got you now. I read your paragraph wrong.
fireloard
2G RDX DIY & FAQ
14
Mar 15, 2016 08:33 AM
