4 Symptoms That Your Connecting Rod Needs To Be Replaced
A connecting rod needs to be strong and durable for the engine to survive. If it’s too weak to handle the load of the combustion, then all the pressure will wear it down and bend it out of shape.
As for the driver, they will be able to notice when this occurs because there will be some very noticeable symptoms present. Below are the top 4 symptoms of connecting rod failure.
Low Engine Oil
If you have a bad or failing connecting rod, then it may cause your engine to consume too much oil. Because of this, you may find that your engine always has a low level of oil.
Either that or your existing oil will need to be changed more often than usual.
Engine Knocking Sounds
When your engine is turned on and running, you may hear a knocking sound coming from it. This will be a repeated knocking sound that gets faster as your engine speed increases.
The sounds may go away after a short while, once your oil has a chance to circulate through the engine components and lubricate them.
Reduced Oil Pressure
A bad connecting rod could have devastating effects on your engine’s oil pressure. There may be an oil pressure gauge on your engine which will tell you when it has low oil pressure.
You could have a warning light on your dashboard that will tell you as well. If you have low oil pressure, then it means the oil cannot circulate properly through the engine.
This might lead to an overheated engine if the problem is not resolved quickly.
Bent or Damaged Rod
If you suspect that you have a bent or damaged connecting rod, based on the other symptoms which may be present,
then you need to visually inspect the rod yourself to see what its condition is.
This would require your engine to be disassembled, which is a job that only a mechanic should do.
If the above situation occurs, then this means that you need to replace the new connecting rod.
MaXpeedingRods high-performance H-Beam connecting rods with Forged SAE 4340 Chrome Moly Steel for the highest strength and durability, dedicated for street and race vehicles.
Get your pistons pumping with tough, top-quality connecting rods from MaXpeedingRods
-------------------------------------------------------------------------------As for the driver, they will be able to notice when this occurs because there will be some very noticeable symptoms present. Below are the top 4 symptoms of connecting rod failure.
Low Engine Oil
Bent or Damaged Rod
for more Honda-related accessories information, enter maxpeedingrods.com
|Facebook| YouTube | Instagram |
The following 2 users liked this post by 1killercls:
Chief F1 Fan (06-09-2021),
teh CL (06-09-2021)
Aman (06-09-2021)
Whatever you can do to get rid of the oil burning...
In any case, connecting rods aren't exactly a wear component lol. Any of those "symptoms" could be, and probably are, one of a thousand other things.
CCColtsicehockey (06-18-2021)
The following 4 users liked this post by horseshoez:
1killercls (06-11-2021),
CCColtsicehockey (06-18-2021),
Sarlacc (06-09-2021)
Note: the context for my comments above are within the realm of a stock production engine operating within normal parameters. Boosting a production engine to say, 67 psi, is an entirely different discussion.
Are you tired of your crankcase lacking large holes to see your internal components?
Are your old cast iron connection rods ugly and not anodized gold?
When your engine builder recommends MAHLE components do you argue with him over price and order the first thing you find with searching cheap critical engine components on duckduckgo.
Then I've got a deal for you.
The following 3 users liked this post by Stapler:
I have never in my 61 years heard of someone having to replace their con rods-ever, unless building a hi perf engine. Why would you give any creedence to this mindless post?? Ask yourself the same question, how many people do you know who had to replace con rods? None. Exactly.
The above said, like I wrote further up thread, I have never heard of a single instance where an engine failure was traced back to a rod failure as the root cause.
Edit: one exception I just remembered. Back when I was working for Mercedes-Benz North America, the CEO of MB-USA was driving his S600 during a torrential rain in northern Bergen County, New Jersey (many of you know what is coming)...
When the car was rolled off the flatbed and into the shop, there was still water leaking from every orifice. For whatever reason, Mercedes decided to rebuild the car versus scrap it; to that end, every wiring harness every electronic component, and all "soft" surfaces were removed from the car and hung up all over the shop walls. Then the engine teardown happened; geez, some of the rods looked like twisted licorice sticks; fortunately the V12 block somehow escaped unscathed, so in went 12 new pistons, new rods, bearings, and a new forged crank. Just the cost of rebuilding the engine alone was $25,000, and this was back in 1996! Funny thing, when the OBC was downloaded, it showed he'd been maintaining about 30 mph through what was over two feet of water; damn, that must have been quite the wake he was creating, errr, right up until the engine went "NOPE", and hydrolocked.
rockstar143 (06-10-2021)
I think you're giving the idiot who wrote the initial blurb way too much credit. I mean seriously, I cannot think of one verified event where an engine failure was traced back to a connecting rod failure, not one. Yes, connecting rods do often suffer damage when an engine fails, but it is rarely, if EVER, the primary point of failure.
It's more than likely a start-up company trying to weasel its way into the market. I'd imagine if they really are good and start gaining popularity, the prices will rise. I've never heard of them, but I also don't go looking for a bunch of different obscure companies who make parts for our cars.
You're pretty much the guinea pig here on how well they'll hold up. To update the thread with info in the future if something, or nothing, happens. I still haven't lowered my car, so if they really are as good as you say they are, I might think about grabbing some.
To ensure that someone may want to know MaXpeedingRods brand, I'd like to give some introductions here.
Established in 2006, MaXpeedingRods is an aftermarket auto parts manufacturer that specializes in conrods, turbos, coilovers, and other accessories. We've accumulated over 4 million customers in the world during these years. As you can see, we started to cooperate with platforms like Acurazine Forum to build this brand. It has grown up in a positive direction.
There are voices on the Internet saying that we only sell cheap products, but the reason is that all our products are produced in our own factories, and sold directly bypassing distributors. That's why our products are comparatively lower than other brands.
MaXpeedingRods started its business with a set of conrods 15 years ago. In the future, we will still aim to manufacture higher quality products both for daily replacement or track use. But on the other hand, to make sure that those modification lovers with a tight budget have access to our parts, the price will still be relatively appropriate. It is our initial intention.
dopeboy1 (06-10-2021)
Because It indeed encountered some problems when applying for the brand name, so it has the MaXpeedingRods you see now.
Wondering that if you guys really used the brand's product? Or just want to bash a new brand based on the first impression?
Personally, this is just a sharing post.
You have the right to agree and disagree. Any words are acceptable, A new brand should experience a stage with suspicion, acceptance, and growing.
I talk here because I see this brand indeed grow better, with my 3 years of work experience together with the brand.
The following 2 users liked this post by Sarlacc:
justnspace (06-10-2021),
Thefireball (06-17-2021)
maxpeedingrods is getting torn apart like their connecting rods.
I dont know anyone who would buy a no name product especially something as crucial as a connecting rod...maybe thats why y'all switched to coilovers?
cheaper to produce and preying on people who want sub $500 modifications (ie; the poor people). Very disgusting to go after the poor. don't get me started on the lack of ethics with the marketing.
The brand's name is shortened from three words: max speed conrods. The company started the business by producing conrods product in the beginning.
Seems that we always see some familiars join discussions in the vendor's posts. It’s a very small number of people that seem to all be mods. When we post about the brand, one of the moderators or their buddy bash the company.
Nicely done.
It's not no name, Justin. Been around since 2006 like my favorite pair of boxer briefs (holes but I still have them).
With that said, these 3 posts are the first ones that make sense to me and seem to address concerns directly.
The hit em fast and hit em hard approach was not the right way to tackle Acurazine to impress your director of Marketing (probably same guy that make the rods).
My honest suggestion is just apologize for spamming members and treating us like tiktok/IG and you'll get the mods and others with half a brain that have been
around for a LONG time on board. Maybe not as far as promoting your product, but at the very least not talking shit every time you post something.
You're trying to be better and we can do the same. That's how relationships work.
FWIW, welcome and let's all get on the same page.
The following 5 users liked this post by rockstar143:
Chief F1 Fan (06-10-2021),
ttribe (06-10-2021),
Yumcha (06-10-2021)
This is a great example of why you should check with a native English speaker when coming up with an English name.
They would have told you that a ding rod could easily mean penis and max pee is very self explanatory.
So your name basically means the most peeing penis. Anyone would think twice before visiting that website.
The following 2 users liked this post by dopeboy1:
"No, I want my name to be Dick."
The American and Canadian crew conspired and we renamed him Elvis. He was initially offended, but when we schooled him on "The Elvis" (Elvis Presley), and then another "Elvis" (Elvis Costello), he instantly warmed up to his new moniker. As far as I know, he still goes by Elvis.
The following 2 users liked this post by horseshoez:
rockstar143 (06-10-2021),
ttribe (06-10-2021)
The following 2 users liked this post by fiatlux:
LOL, this reminds me of when I was developing a custom MRP system for a U.S. based company working with an Industrial Design firm in Norway and an injection molding factory in Taiwan. On one of my visits to Taiwan they'd hired a new/young engineer, a tall handsome fair skinned and dark eyed and haired kid who'd chosen his English name as Dick. Those of us from the North America were like, "Oh no, not happening! You need to choose a different name."
If so, he doesn't go by Elvis...
horseshoez (06-10-2021)
Sending emails to Peter Pan, like, “who the fuck does this guy think he is?”
horseshoez (06-11-2021)
