1987 Ford Mustang - 400HP & 110 MPG
http://www.leftlanenews.com/best-mec...n-110-mpg.html
Best mechanic ever: Ohio man tunes Ford Mustang to produce 400 horsepower and return 110 mpg
With gas prices setting record highs nearly every day, many Americans are being forced to trade in their performance cars and large trucks and SUVs due the high price of a fill up. But one Ohio man’s invention could be setting the stage for a V8 return.
Napoleon, Ohio’s Doug Pelmear claims that he has created a V8-powered 1987 Ford Mustang that develops 400 horsepower and 500 lb-ft of torque on E85, can accelerate from 0-60 in about three seconds – on its way to a top speed of 180 mph – and still returns an astonishing 110 mpg.
Although a 400 horsepower economy car sounds too good to be true, Toledo’s Rocket Ventures, a subsidiary of the Regional Growth Partnership, has verified Pelmear’s claim, according to OzarksFirst.com.
Pelmear has yet to reveal what’s exactly under the hood of his Mustang – as he’s still waiting on a few patents – but says his work is based off the work of his grandfather who developed fuel-saving techniques during the 1940s.
Pelmear has even entered his car into the Progressive Automotive X Prize, one of the world’s foremost green car competitions that challenges contestants to “design viable, clean and super-efficient cars that people want to buy.” If you ask us, the judges should just hand over the $10 million grand prize to Pelmear right now.
Some dude
If true, this is the greatest news US manufactures could have ever heard.
The sizzle in the Steak
He uses this:
no sh*t.. that guy better watch his back!!
wtf.
WTF?
I could be getting 5x better gas mileage? Who's been holding out on me? And of all things, he put it in a Foxbody
WTF?
Total BS.
Think about it for a second, the engine he is using used to get about 14mpg. now it gets 110. If you assume that 110 is the max, that means 110 is 100% effeciency and he was previously only getting a little less than 13% effeciancy out of the gas he was using. How could an engine POSSIBLY be that bad? The answer is, it couldnt. I could make an engine out of Legos that would be more efficient than 13%. This is complete and utter BS.
Originally Posted by TzarChasm
Total BS.
Hardly impossible IMO..........................
Don't Mess With Texas
Originally Posted by DarkSithCL
I am calling that guy comes up missing via the oil / gas companies...... they didn't say what happened to his grandfather.... did they?...
E92
Even if his claims are true, it's still E85. It's not a viable to any of our problems since we can't grow even close to enough corn, and less clean than gas. There are more reasons E85 sucks but I won't get into it.
Total BS.
An internal combustion engine is a heat engine. The engine and fuel start out in one thermodynamic state and then through the 4 stroke cycle, the fuel is turned into heat and turned into mechanical energy. The very fact that all car engines have a cooling system to remove excess heat means that not all of the heat being created is used.
Also, take into consideration that the car in question is a 1987 50 Mustang, not exactly known for efficiency.
I'm not saying this story is true, but IC engines are far from efficient.
seizure force field!
This guy sums it up pretty good:
Fuel mileage is limited by the energy content of the fuel, the laws of thermodynamics, and by frictional and aerodynamic loses. Gasoline has energy of combustion 11,000 calories/gram. That is the maximum energy that can go into a gasoline engine. The useful work is limited by the engine’s efficiency. The thermodynamic ideal gasoline engine is governed by the Otto cycle, which is a function of the compression ratio. The higher the compression ratio, the greater the engine efficiency. For a compression ratio of 10:1, the Otto cycle efficiency is approximately 60%. This means that you should expect 6 gallons of work out of every 10 gallons of gasoline.
However, real cars are effectively much less efficient than the Otto cycle. They may do about 12-15%. Heat losses, braking losses, drive train losses, rolling resistance, aerodynamic losses…the list goes on. The automobile manufacturers have actually done an excellent job in reducing these loses. The question remains: Just how realistic is the claim of 110 mpg?
It turns out that an ideal Otto engine driving a car at 60 mph with no rolling resistance requires a coefficient of drag of 0.33 to achieve this fuel economy. A somewhat less slippery car should be able to do it at slower speeds. The bugaboo is that this scenario requires substantial reductions in all loss mechanisms–unrealistic reductions. The claim is that the super efficient Mustang is powered by a 400 hp engine. However, it can produce no more than 17 hp at cruising speed in order to get 110 mpg.
but even if hes getting half that mpg, I would give em props.
Originally Posted by wackjum
While I don't believe this guy's claim either, 13-15% efficiency out of an internal combustion engine is normal.
more information for people:
Most steel engines have a thermodynamic limit of 37%. Even when aided with turbochargers and stock efficiency aids, most engines retain an average efficiency of about 20%.[7][8]
Disinformation Terminator
Hey, I can't get past 400hp in a Fox Mustang doing 0-60 in 3 seconds.
Not without wrinkle slicks, a 3000rpm stall, a locker diff, and a nicely seasoned dragstrip.
110 mpg? Don't go there....
with a 400 hp v-8 i don't believe it. Hell i don't even believe it with a v-6.
a car with that much hp , and that old(21 years old) isn't gonna do 110mpg.
i'd say even if he drove it like a grandma and shifted at fairly low rpms 18-19 mpg. and that's no traffic or not to many lights.
Hell a Prius is only doing like 50-55 mpg and that's all highway and that only has 1/4 of the hp of this animal.
He is not getting 110 mpg when using all of the 400 hp. If his turbo is set to kick in at 5000 rpm, and he is cruising at 3000 rpm, then it makes sense that he is sipping fuel, because he it's a 4 cyl after all. Step on the gas and you'll see the true mpg...
09-25-2015 06:14 PM
