FS: Custom Axle Back Exhaust, High Output Alternator, Custom Front Grille & Door Sill
These were on my 02 Acura CL Type S. It should fit all 01-03 CL's and possibly TL's
Custom Axle Back with BOMZ Mufflers: $175 Shipped OBO Email me if you want a video emailed to you. This is a direct bolt-on!
180 Amp High Output Alternator from 4Alterstart.com($299 new). Used for 4 months: $200 shipped OBO
Custom Front Mesh Grille: $20 shipped
One Door Sill Acura Cl-S: $10 shipped
Grille is sold to Dunndada. I'll PM you now with my info.
In reference to the alternator....this is what their site states. You may want to call them at 1-800-607-0016
97-01 NEW ACURA CL, TL HIGH OUTPUT ALTERNATOR 180 AMPS
Lifetime Warranty!
Stronger is Better!
Upgrade your:
98-02 Honda Accord
97-00 Acura CL (3.0L engines)
2001 CL w/3.2L and 2000 TL w/3.2L
This alternator is made to run stereo cars, CB hi watt amps, winches, light bars, spotlights, etc. It has a tough diode package with 50 amp 200-volt diodes and an extra-heavy-duty voltage regulator and improved bearings by NTN.
It's twice the alternator at only 25% additional cost.
The cs130d unit includes an internal cooling fan and modern design. A drop in unit requires no modification to the bracket system.
A four-gauge battery power cable is recommended to replace the existing battery wire to the back of the alternator.
Available on this site.
Note there is no difference in the case between the 180 amp alternator and your factory 105A unit.
Fits without modification.
This alternator will provide 85 amps at 800 engine rpm and 180 amps at 1800 engine rpm.
This unit is factory load tested and ready to install.
Lifetime Warranty!
Stronger is Better!
Upgrade your:
98-02 Honda Accord
I forgot to mention...the grill only includes the mesh. The Acura emblem is not included. You should already have the emblem on your stock grill.
AcuraCL1: I never heard any whining sounds from the alternator.
OU SIG: I was running around 3000 watts rms, but of course...that wasn't 24/7. I no longer had dimming issues. My main amp was a Concept 2400d which I had wired down to 1 ohm and puts out 2400w rms.
umcp I'll let you know if Dunndada doesn't want it.
PROUD TL OWNER
i am intrested in your wexhaust i want the video if you can send it to my email at armssosmall2000@YAHOO.COM
I am also interested in the exhaust and live in Ft Lauderdale Please email me the vid also Quad150db@yahoo.com
09-04-2015 08:03 AM
