Continual ECM reset with key method
Old Sep 21, 2014 | 11:12 AM
Jackel001's Avatar
Hi everyone. Just joined your group. I am impressed with everyone's knowledge of Acura products.
I am having a problem with a non-start issue. I have a 2002 MDX on Propane with 222,000 km's on it. I had a full transmission oil change a month ago. Trying to start the car a few days later it took several tries to get it to start. The next day it would not start at all so I tried an ignition key ECM reset. The car started right away. This is happening with more regularity lately. Has anyone experienced this and if so what was the outcome for repairing the issue. I am just guessing that the trans oil change set this off but am not sure. Also on occasion the no charge light and ABS light will flash when I step on the brake.
Old Sep 25, 2014 | 06:57 PM
Jackel001's Avatar
Problem solved...fuel pump was getting random garbage electrical signals and would not energize properly
Old Sep 29, 2014 | 09:18 AM
StanCeD_J32's Avatar
-NoSuchThingAsTooLow-
was late on seeing this! good thing you got it figured out..did you fix it yourself? or take it to a shop
Old Oct 2, 2014 | 08:57 AM
Jackel001's Avatar
Ended up taking it to a mechanic that knew what he was doing.
Jamus22
Jun 11, 2023 10:08 AM
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
malvothegreat
Sep 29, 2015 12:38 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
