Looking for a sharp Nikkor zoom lens
I'm looking for a Nikkor zoom lens (around $400-500) that'll take very sharp images. I was looking at:
AF-S DX Zoom-Nikkor 18-70mm f/3.5-4.5G IF-ED
AF Zoom-Nikkor 28-105mm f/3.5-4.5D IF
What do you guys think about the lenses mentioned above?
Are there other lenses you guys would recommend?
The 28-105 is the higher rated of the two but they are both quite different. The 18-70 is a DX lens so it's designed for the DSLRs. If you're shooting film, I don't think you can use this lens. Otherwise, it just comes down to what you value: wide angle or telephoto. 10mm on the wide end is a significant difference.
What other lenses do you have? If your camera is digi, the 28-105 (42-157mm equiv) might be a little long for a walk around lens.
Thanks.
Originally Posted by TSX7
I have a Nikon D100 with 50mm 1.4 Nikkor lens right now so I'm looking for a decent zoom.
Thanks.
Thanks.
You also speak of sharp. Well, the sharper the optics the more it will cost you.
Define sharp. Pretty all the nikkor lenses will give you a sharp image. The higher quality ones will give you the best.
this is a little above your price range but for what the lense is I think it would fit your needs well.
AF-S DX VR Zoom-Nikkor 18-200mm f/3.5-5.6G IF-ED (11.1x)
LINK
http://www.ritzcamera.com/product/541530721.htm
LINK
