Fujifilm FinePix X100
Received 2,811 Likes
http://www.dpreview.com/news/1009/10...jifilmx100.asp
Pre-Photokina 2010: Fujifilm has announced the X100, a large-sensor compact camera aimed at professional and enthusiast photographers. Based around a 12Mp APS-C CMOS sensor, Fuji EXR processor and 23mm F2 Fujinon lens (equivalent to a 35mm semi-wideangle), the classically-styled camera features traditional analogue controls for shutter speed, aperture and exposure compensation. Of particular note is the new 'hybrid' viewfinder system which allows the user to switch between optical and electronic viewfinders and project detailed shooting information into the OVF. The spec is rounded off by 720p HD movie recording, a 460k dot 2.8" LCD, flash hot shoe, and magnesium alloy top and base-plate castings. The camera will be available from early 2011.
Press Release:
FUJIFILM announces FinePix X100
PHOTOKINA 2010, COLOGNE, GERMANY, September 21, 2010 — FUJIFILM Corporation is pleased to announce the new FinePix X100, a high-grade digital compact camera featuring an APS-C CMOS sensor, a Fujinon 23mm fixed focal length lens and a newly developed Hybrid Viewfinder, due for commercial release in early 2011.
The FinePix X100 is aimed at the professional photographer or keen enthusiast looking for exceptional quality pictures from a compact camera. It is designed to appeal to the millions of DSLR users who need a slim back-up camera for high quality in-fill shots when the use of a bigger SLR system is either inconvenient or impractical. Or, of course, it can be used as a professional’s only top-end camera, if size and versatility are the primary considerations.
Fujifilm has closely studied the current line-up of professional cameras and feels that there is a strong need for a compact high-quality (APS-C based) camera as a counterpoint to an SLR. Using the experience of working with generations of photographers using famous emulsions like Velvia, Provia, Astia etc., Fujifilm engineers distilled this knowledge into months of careful study to create the perfect compact-sized professional camera.
The priority for this model is picture quality, so it was decided to make the highest quality possible lens and sensor combination, built from the ground-up. The lens chosen is a fixed, prime F2 lens, made by Fujinon, manufactured to perfectly match the APS-C custom sensor. Added to this is the newly-developed EXR Processor, which combines all the latest image processing technology Fujifilm has built up over the years.
Other cameras on the market look to fill the need for the ultimate ‘compact’ professional camera, but the Fujifilm development team believe that, having listened to the marketplace, the FinePix X100 offers a number of technical developments that will set this camera apart from other contenders. The main technologies employed in this camera are as follows:
Hybrid Viewfinder New Development
The Hybrid Viewfinder on the FinePix X100 combines the window-type “bright frame” optical viewfinder found in high-end film cameras such as 35mm or medium-format cameras, and the electronic viewfinder system incorporated in fixed single lens or mirrorless digital cameras. By integrating a prism for the 1,440,000 dot LCD panel image on the viewing screen in the reverse-Galilean optical finder, the Hybrid Viewfinder can show both the shooting frame and a variety of shooting data.
It can also be used as a high-quality electronic viewfinder to compose or playback shots, with the ability to instantly switch between optical and electronic viewfinder images with simple “one touch” control. The new Hybrid Viewfinder offers users expanded freedom in the composition and enjoyment of photography in a range of challenging shooting conditions.
While digital compact cameras have become ever slimmer and more compact in recent years, composing and viewing shots on large, higher resolution LCD panels on the back of the camera has become the mainstream practice for today’s users.
On the other hand, shooting with an optical viewfinder is the standard practice for conventional film cameras and the preferred method for large numbers of digital camera owners. Many prefer the finder to be as close as possible to the eye, so the user can focus attention exclusively on photo composition, to get a clear view of the subject without distraction.
While traditionalists prefer the clear, sharp view of an ‘optical’ finder, modern electronic displays, giving data like shutter speed, aperture, white balance, exposure correction and sensitivity can aid the photographer tremendously. The new Hybrid Viewfinder on the FinePix X100 aims to give the user the ‘best of both worlds.’
Further specifications for the Hybrid Viewfinder are as follows:
The reverse Galilean optical finder with a 0.5× magnification features all-glass elements made from high-refractive index glass and demonstrates low chromatic aberration and distortion.
In optical viewfinder mode, the brightness of both the “bright frame” and text data is automatically adjusted according to the brightness of scene area, ensuring that shooting information is always easily and clearly viewable.
Displayed shooting data is constantly updated according to changes in shutter speed, exposure, sensitivity and other settings.
In electronic viewfinder mode, the photographer can preview the picture or playback the result with the “through the sensor” image review. Available with one-touch switching ease, this capability enables the user to preview and confirm exposure settings, depth-of-field effects, white balance, and macro shots.
12.3 Megapixel APS-C CMOS Sensor
The FinePix X100 features a custom CMOS high-performance sensor, internally optimized and developed exclusively for this model.
Optimization of the angle-of-incidence in conjunction with the specially developed lens maximizes light gathering efficiency extending to the perimeter of the sensor for a sharper image with exceptional clarity.
When shooting HD movies, the combination of the large-sized sensor and the large aperture F2 lens, lets users shoot a soft out-of-focus touch (bokeh) — a capability not available in conventional compact cameras.
The ideal combination of a fixed focal length lens, high-sensitivity sensor (approx. 10 times the sensitivity of a conventional compact*) and a high-performance image processor captures exceptionally high-quality images over the entire sensitivity range from low to high ISO settings.
The high-speed CMOS sensor read-out and the EXR Processor’s enhanced focusing system contributes to the high-speed AF performance, while the combination of the optical viewfinder and extremely low shutter time lag enhance the pleasure of every shot.
23mm F2 Fujinon (Aspherical) Lens
The newly-developed lens offers a focal length of 23mm (135 equivalent: 35mm) and a widest aperture of F2. Made from moulded glass, the lens contains 8 elements in 6 groups.
The adoption of the non-collapsible lens structure with minimized lens length not only contributes to the compact size but also eliminates telescoping of the lens when the power is on. It’s ready to start shooting the moment you turn it on.
Exploiting the merits of fixed focal length lens, this lens delivers sharp resolution of the total image from the centre to the corners. In addition, the lens features not only the large F2 aperture value, but also an optical architecture that maintains a high degree of resolution even when closed by 1 to 2 stops.
The lens uses a 9-blade aperture diaphragm. A large F2 aperture and high-quality optics let users take beautiful photos with a soft out-of-focus (bokeh) effect.
The lens enables macro shooting as close as 10 cm.
Featuring a built-in ND filter (equivalent f-stop reduction of 3), the lens can enhance depth-of-field even in bright shooting conditions by enabling the aperture to be kept wide open. Shutter speed can also be reduced to capture waterfalls, or any shot where intentional blur is required.
EXR Processor Newly Developed
When combined with the high-performance lens and high-sensitivity sensor, the newly developed EXR Processor achieves the highest definition, sensitivity and wide dynamic range image quality of any digital camera produced by Fujifilm.
Throughout development of the processor, Fujifilm has re-examined every aspect from response to the circuit structure, and achieved a significant leap in signal processing performance for a more responsive and faithful reproduction of the image.
The graphical interface (style and rendering of the LCD information) has been upgraded in the newly developed LSI to enhance the user experience and to improve the clarity of the information presented.
Design
Inspired by the beauty and form of classic cameras from the past, the FinePix X100 combines all the latest technical digital innovations in a beautiful, traditional chassis which oozes class and prestige.
The ergonomics of the design offer the perfect balance between compact convenience and user-friendly operation.
The camera controls have been carefully thought out to give the photographer simple and speedy access to aperture, shutter speed, ISO etc, to allow maximum creative expression with minimum hassle. Custom modes can also be used for a one-touch change in settings.
The upper control deck/bottom surface has been cast from magnesium alloy (semi-solid metal casting) to contribute to a high-precision camera body with high rigidity.
All dials on the upper control deck are fabricated from metal. Adoption of traditional ‘manual’ dials lets the user confirm the position of the settings without turning on the power.
*Comparison with other FinePix compact camera models.
Fujifilm X100 camera specifications
Sensor • APS-C CMOS sensor
• 12.3 million pixels
Movie clips • 1280 x 720 pixels (HD)
• with stereo sound
Lens •Fujinon lens with Super EBC Coating
• F2-F16
• Focal length : 23mm (35mm equivalent)
• 9-bladed aperture diaphragm
• 10 cm minimum focus
• Built-in 3 stop ND filter
Focus • High-speed contrast AF
ISO sensitivity • ISO 200
• ISO 400
• ISO 800
• ISO 1600
• ISO 3200
• ISO 6400
(ISO 100 - 128000 in expandable mode)
Shutter speed • 30 sec. to 1/4000 sec
Exposure Modes •Programmed AE
•Aperture Priority
• Shutter-Priority
• Manual
Continuous shooting 5 fps
Optical Viewfinder 0.5X magnification with approx. 90% frame coverage
Electronic Viewfinder Ultrafine 1,440,000-dot LCD
LCD monitor •2.8-inch
•approx. 460,0000 dots
Storage SD / SDHC / SDXC memory card
Power TBC
Weight TBC
Dimensions 127(W) × 75(H) × 54(D) mm
Additional images
Press Release:
Design
• with stereo sound
• F2-F16
• ISO 400
• ISO 800
• ISO 1600
• ISO 3200
• ISO 6400
•Aperture Priority
• Shutter-Priority
• Manual
Power TBC
Weight TBC
Additional images
This is will a nice camera, "if" it can focus fast and is NOT overpriced.
The Third Ball
Received 5,105 Likes
Let's see how the image compares to the Olympus and the panasonic. This could be a winner.
A rangefinder in silver with black textured grip. It even has the self timer thing on the front. This is my weakness.
Perhaps I'm not seeing something but it doesn't look like the lens is removable. It may not be competition for those other cameras in that respect.
looking forward to sample pics.
Is NOT an interchangeable lens camera
Creepy guy in the mirror.
I am loving the looks of that camera... I just don't know about the real practical use of a camera with a fixed focal length without a detachable lens.
I still want one... I wonder what the price point will be?
I heard someone throw out the number "1500".... at that range, I would never ever be interested in this camera.
yea i saw that too...
The Third Ball
It is a fixed lens camera which doenst bother me...as this is similar to what I want.
BUT 1500...no way in hell, this needs to be closer to the 800 price tag the micro 4/3s are carrying.
More and more what I'm seeing from this, $1500 is a good price. This thing is going to be built like the old rangefinders, classy and like a tank. It might be a little hard to drop $1500, but I would drop it before $800 on a 4/3 camera.
The Third Ball
$1500 can get me a D7000 with 1080P video and change to spare.
But it won't fit in your pocket
depends on what kind of pants you're wearing...
http://www.engadget.com/2010/09/21/f...0-we-go-hands/
Fujifilm's FinePix X100 ships March 2011 for $1,000, we go hands-on (update: video!)
Posted Sep 21st 2010 8:12AM by Darren Murph
It's fitting that Fujifilm's thoroughly gorgeous FinePix X100 kicked off this week's flood of Photokina releases, and now we've learned a few more precious details from the outfit's press conference. For starters, it'll be a non-zoom apparatus, much like Olympus' Zuiko-equipped concept that was also launched here in Köln. Fujifilm's Adrian Clarke noted that the decision to include only a 23mm f/2 fixed lens was made in order to not make image quality compromises that are necessary when allowing for a zoom. We're sure that'll strike some as displeasing, but those who aren't afraid of moving forward and back could probably care less. Furthermore, he affirmed that the company was aiming for a March 2011 ship date, with a retail price to hit near the $1,000 mark. That's hardly affordable, but Fuji's making no bones about this being a decidedly high-end piece.
After the presser, we were able to score some hands-on time with a pre-production model, and we have to say, this thing just feels like a thousand bucks. It's as solid as a stone, though light packers won't appreciate just how heavy it is. Regardless, the body exudes quality, and the grip was as comfortable as ever. Sadly, no fully functional units are present here at Photokina, but we're cautiously optimistic that we'll see one at CES. It's doubtful that Fuji will sell oodles of these given the limitations and price, but to the niche that's interested, things are looking up.
Update: We just stopped by the Fujifilm booth in order to grab some video time with this guy, and sadly, the model that they had on display lacked a sensor of any kind. However, the dedicated toggle switch to flip between the OVF and EVF is a lovely touch, as were the dedicated control dials up top. Have a look yourself just beyond the break.
arshu78
20
10-27-2009 03:32 PM
CGTSX2004
10-06-2009 08:30 AM
CGTSX2004
09-28-2009 06:25 AM
CGTSX2004
1G TSX Photograph Gallery
43
05-14-2008 04:39 PM
CGTSX2004
05-12-2008 09:23 AM
