Cameras & Photography Because there aren't already enough ways to share photos...
Compact flash card help?
Old May 30, 2007 | 04:48 PM
  #41
srika's Avatar
Moderator Alumnus
even better
http://www.adorama.com/ILXCRCFPU.html
with $30 rebate
Old May 30, 2007 | 04:50 PM
  #42
Billiam's Avatar
Big Block go VROOOM!
Originally Posted by srika
im gonna get this and see how it works
http://www.adorama.com/IDSDRN1901.html
Interesting that Sandisk states that this reader will do CF Type II and Memory Stick Pro Duo but not SDHC. I wonder if perhaps it actually will read them and the unit (and its description) simply came out before SDHC hit the market.
  #43
srika's Avatar
Moderator Alumnus
Originally Posted by moeronn
That's pretty rediculous. If it took that long to copy 8GB, I would understand.
The idea of having 2x4GB is a good one. Too bad no one suggested that earlier.
I will respond to this after I get my new reader. :P
Old May 30, 2007 | 05:00 PM
  #44
jupitersolo's Avatar
nnInn
even better
with $30 rebate
Yeah, let us know about this one.
Old May 30, 2007 | 05:07 PM
  #45
Dan Martin's Avatar
Photography Nerd
You need to check out the database at RobGalbraith.com: http://www.robgalbraith.com/bins/no_...?cid=6007-8471
Cards seem to need to be matched to the reader for best performance. If you're primarily using Lexar cards, I'd stick with the Lexar reader. There is a memory controller on the card and one in the reader. If they "talk nicely" to each other, then you'll get the best transfer rates. Also, it seems that firewire is still quite a bit faster than USB, even though the cards shouldn't be coming anywhere near the maximum transfer rate of either interface.
Old May 30, 2007 | 05:12 PM
  #46
srika's Avatar
Moderator Alumnus
thanks - just remembered I have firewire on my laptop... guess Ill get that!
Old May 30, 2007 | 05:16 PM
  #47
Billiam's Avatar
+1 (Macbook Pro)
Old May 30, 2007 | 05:18 PM
  #48
srika's Avatar
Moderator Alumnus
dang.. crazy thing about that chart - the performance of the higher capacity cards goes UP compared to the other capacities, with the faster readers!! ~16mb/sec for the 8gb.
Old May 30, 2007 | 05:20 PM
  #49
srika's Avatar
Moderator Alumnus
dang i feel like such a nub... too many times in here. x 1 billion..
Old May 30, 2007 | 07:13 PM
  #50
ChodTheWacko's Avatar
Moderator Alumnus
im using a 2.0 reader.. on a Core 2 Duo laptop.
Have you tried the combination on another machine?
It sounds like USB 1.1 speeds. Are you sure USB2.0 is enabled in BIOS and
in windows/whatever? It should not be so slow.
- Frank
Old May 30, 2007 | 10:16 PM
  #51
srika's Avatar
Moderator Alumnus
- Frank
its taking 6 minutes on an older P4 desktop... and I have a correction, this was for 1.72GB. I guess I just assumed it was working OK on the laptop, since I did not get any of those "this device can perform faster" popups... looks like I have to check the USB2.0 software on there, since I did reinstall the OS (reformatted, not using out of box). Thanks Frank, I totally didn't consider that possibility.
Old May 31, 2007 | 09:22 PM
  #52
Billiam's Avatar
A quick trip to Wikipedia answered my own question.
SDHC uses the same form factor as SD, but the SD 2.0 standard in SDHC uses a different memory addressing method (sector addressing vs byte addressing). SDHC cards only work in SDHC compatible devices, but standard SD cards work in both SD and SDHC devices.
Old Oct 17, 2007 | 06:38 PM
  #53
Moderator Alumnus
I just got an Sandisk extreme III 4 GB CF from amazon.
I opened up the box to find not only photo recovery software, but a free license (2 activations) for Capture One LE! Neat.
Also note on the above comment - the bottleneck could have easily been the laptop's hard disk. I can transfer to my laptop MUCH faster now that I got a faster HD for it.
- Frank
Old Oct 18, 2007 | 01:12 AM
  #54
BIGTUFFGUY's Avatar
2003 TL-S A-SPEC
i have the XT and 2 1gig Extreme III
I once filled a card by holding down bust mode. Never did the camera have to wait for the card. everything went flawlessly.
transfering onto the PC takes about 45-50 seconds per cardwith the 12-1 Sandisk Card reader.
plus with the extreme cards you get a pouch and recovery software.
I STRONGLY recomend extreme or up.
Old Oct 18, 2007 | 02:10 PM
  #55
lcrazyaznl's Avatar
CL9 ABP
Awesome to know guys unfortnately my camera was stolen the following few months later.
It was in my car and the window was smashed so i didn't go back to the rebel xti and swapped over to a nikon d80. =\
dirleton
Aug 6, 2024 08:19 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
thegipper
Sep 28, 2015 01:01 PM
ceb
ILX
Sep 27, 2015 10:56 AM
kixo
Sep 25, 2015 03:07 PM
