Canon EF 80-200mm f/4.5-5.6 Zoom Lens
Big Block go VROOOM!
It doesn't even look like B&H or Adorama carry that lens so I have no idea how much it costs. Relative to Canon's own lineup, it appears to me as if this particluar lens is in the "bottom feeder" catagory. It's not even USM which means the autofocus will be pretty slow.
TSX
Received 2,782 Likes
how much does it go for?
Not Registered
The EF 80-200mm was introduced back in 1995, they are still around, but I'd get the Canon Zoom Telephoto EF 75-300mm f/4.0-5.6 III USM for $179.00 if you want a decent kick around zoom lens.
Photography Nerd
Originally Posted by Savio
how well does this lens do at night?
What are you thinking of shooting at night?
Have camera, will travel
At f4-5.6 it's on the slow side. It depends on what you mean by how does it do at night. For handheld low light photography, it's not going to be the best. For tripod mounted land/cityscapes it would probably be fine.
Edit: Quick draw beat me to the punch.
TSX
Originally Posted by Dan Martin
I guess that question depends on your conditions and what you're shooting. If you're shooting a baseball game under stadium lighting, both lenses will probably be too slow unless you use a very high ISO. If you're shooting a stationary landscape shot and you're using a tripod, then you'll be fine.
I need to do City shots at night but I want to have the option of bringing it to a hockey game or basketball game also...
Not Registered
You can look here to see what kind of shots people are getting with a 75-300mm f/4.0-5.6 lens. It's basically an outdoor lens, it's not going to work that good for a basketball or hockey game unless your on the sidelines shooting high ISO 75mm at f4. Hockey possible, since it is bright there with the ice... just shoot goalies, they don't move that much.
http://www.pbase.com/cameras/canon/ef_75-300_4
Photography Nerd
Most basketball courts and hockey stadiums are very dim. Pros typically cover those events with strobes, fast primes, and f/2.8 zooms. Of course pros usually have larger budgets than the average hobbyist, so you'll have to compromise somewhere. Long and fast lenses are big bucks.
You could go with something along the lines of an 85mm f/1.8 which will let you shoot available light at moderate ISO's in most stadiums. Or, if you're able to use a hotshoe flash, the zoom should be ok. It will be tricky to shoot through the glass with a flash at the hockey rink though. The 85mm also makes for a great portrait lens, if you want to get some dual-use from your kit.
The key will be to buy from a shop that has a liberal return policy. You'll really need to try both to see which lenses suit your needs the best.
is learning to moonwalk i
I kAnt Spel guD
The Canon 75-300mm is tough for sport use, it's a very slow AF lens by Canon standards.
The Sigma and Tamron zoom 7x-300mm for under $200 are sometimes suggested over the Canon models.
But I think you will be much happier with the results from either of the Canon USM prime lenses in all seriousness.
The 100mm/2.0 was used in tandom with a D30 and D60 in a church at nigth some years back for our wedding with amazing results. It's a sweat heart lens that hardly ever is recommended.
I just bought this lense. I'm just starting out with my first DSLR, so I hope to get the hang of the camera and the lense fairly easily. I heard so-so things about the kit lense, so I got this separately instead. It's $299 at Best Buy. Hopefully it will meet my needs as a beginner, but also be a decent lense that I can keep for a while.
Canon EF 28-105mm f/3.5-4.5 II USM Zoom Lens
Compact zoom lens for EOS cameras with built-in flash
15 elements in 12 groups
Angle of view: 75°-23°20'
Minimum aperture: f/22-27
Maximum aperture: f/3.5-4.5
Minimum focusing distance: 1.6' (0.5m)
Filter size: 58mm
Wide zoom ring for more positive operation
Product Details
Warranty Terms - Parts 1-year limited
Product Weight 13.1 oz.
Product Depth 3"
Range 28-105mm
Lens 28-105mm zoom
Focus Range 1.6' - infinity
Autofocus Yes
Aperture Range f/3.5 - f/4.5
Filter size: 58mm
Product Details
Product Depth 3"
Range 28-105mm
Lens 28-105mm zoom
Autofocus Yes
I kAnt Spel guD
Filter size: 58mm
Product Details
Product Depth 3"
Range 28-105mm
Lens 28-105mm zoom
Autofocus Yes
Filter size: 58mm
Product Details
Product Depth 3"
Range 28-105mm
Lens 28-105mm zoom
Autofocus Yes
BTW, you may want to check out BHphoto in NYC for your camera gear, unlike most they are reputable.
Originally Posted by MrChad
that is anything but a so-so lens, a little long for a 1.6x DSLR but it was a very good lens in the film days.
^^^ Also take a look at www.amazon.com, they have the lens for $240. No tax and free shipping. I won't buy anything from bestbuy unless I have to have same day, and that's not most days.
Filter size: 58mm
Product Details
Product Depth 3"
Range 28-105mm
Lens 28-105mm zoom
Autofocus Yes
Filter size: 58mm
Product Details
Product Depth 3"
Range 28-105mm
Lens 28-105mm zoom
Autofocus Yes
Here are some things I have shot with that lens:
http://www.bboyhp.com/photos/detvsnets/detvsnets.html
https://acurazine.com/forums/showpos...39&postcount=5
you'll enjoy it.
Originally Posted by badboy
I have that lens...and I have to say I am happy with it.
you'll enjoy it.
you'll enjoy it.
I kAnt Spel guD
http://emedia.leeward.hawaii.edu/fra...m#28-105Anchor
The 28-105mm is a very good lens for the coin. The 58mm filter size matches very well with some other good Canon lenses.
50/1.4; 100/2.0; 100-300/4.5-5.6; and 70-300 IS USM come to mind.
My wedding was covered completely by my photographer back in the day with a 28-105/3.5-4.5; 100/2.0; and the 75-300/4-5.6 IS USM lens. on pair of D60's and a D30. This was prior to digital specific glass by the way.
With a good flash like the 430EX and a good tripod many magical things can happen with that 28-105mm USM lens.
For what it's worth you can purchase the proper Canon matching lens hood for that lens online as well. That's a good investment if you plan to keep the lens for a bit.
And the USM autofocus will spoil you against most 3rd party glass I'm afraid to say. That's one of the best lenses for a starter kit IMO. The only lens I could see as maybe being better is a Nikon the 18-70mm/3.5-4.5, I really wish Canon would make a sub $300 twin of this excellent Nikkor.
I kAnt Spel guD
^^ Awesome. I'll look into the flash and lense hood, and I plan on getting a tripod. This is going to turn into a fun hobby.
Haha, yeah, I have to remember to keep things under control financially, since I am trying to save for a house. Photography looks to be a VERY expensive hobby.
I kAnt Spel guD
Canonitus and Nikosis are expensive:/
Both are deseases characterised by uncontrollable gear acquisition syndrome...
TSX
alright.....
my new budget is 150-275
Here is what I'm looking to do in order of preference...
1. Night shots of city
2. Action shots of baseball/soccer/tennis/basketball games (sometimes at night also)
3. Portrait shots
Also let me know of a decent flash if possible. For the action shots, I don't know how close or far away I'll be. Maybe in the stands...
3. Portrait shots
im kinda tempted to sell my 70-300 IS USM for a 70-200 F/4 i like the idea of the constant aperature and non rotating front element
but man that IS is nice
^^ The constant aperature isn't that big of a deal. The larger aperature does make a difference, though.
Also, unless you are using filters, don't worry about the rotating front element.
Anyway, I'm still pretty happy with the 70-300. It has served me well and will work for now. Having the 70-200 F2.8 on the XTi looked pretty ridiculous. I think once I get a bigger more expensive camera will be the time I start thinking of the 70-200 again.
ohh yea im perfectly fine with the 70-300 it serves me well, but i think later on i want to get something faster, so eventually i want to get the 70-200 2.8 and pair that up with the 24-70 2.8
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
