TSX Type-S THIS Fall?
Old Jul 11, 2003 | 01:26 AM
RJC RSX's Avatar
Heh I'm pretty doubtful, but a salesperson at Pohanka Acura in Chantilly told my dad that a type-s version of the TSX would be available this fall... I don't suppose there could be any truth behind this?
Old Jul 11, 2003 | 04:05 AM
ncsustash's Avatar
none-zip-zero
I have serious doubts that there ever will be one because the car is ABOUT at its limits---getting a V6 in the bay would be difficult and the suspension is already pretty sports tuned.
BUT if you look at acuras release of Type-S cars the earliest you could expect it is in 2 years as a mid product cycle refresher
Old Jul 11, 2003 | 06:02 AM
moda_way's Avatar
I've posted a message many times, but I have a source at Honda who has said this to me:
1. You'll never see a V6 in the TSX.
2. The earliest possible chance, assuming TSX sales went crazy, would be next year, but doubtful b/c the TSX is still so new over here.
Old Jul 11, 2003 | 09:39 AM
ebcheon's Avatar
i really doubt that the TSX will ever be available in a TSX-S. first off, type s means that it will have a stiffer suspension. the TSX already comes with pretty stiff suspension. secondly, what model from previous acura models changed their engine from a 4 cylinder to a 6 cylinder? or perhaps a 6 cylinder to a 8 cylinder? not a one... all type s cars stay w/in the same cylinder size, but upgrade the hp. they only room for improvement i could see would be a s2000 engine in the TSX, but not a v6.
Old Jul 11, 2003 | 10:21 AM
DEVO's Avatar
Not this again... anyway just an FYI, the Acura TSX that you guys are so fond of is a Type S (actually a little better) Euro Honda Accord....... in other words, you are driving a Type S version.
Old Jul 11, 2003 | 10:42 AM
RJC RSX's Avatar
Sorry to bring up this up then. Of course the TSX will never see a V6 since it physically isn't possible, but in 2 years I wouldn't be surprised if a TSX Type-'R' came out with AWD and a souped up I4.
Old Jul 11, 2003 | 11:38 AM
captainjack's Avatar
Über Geek
Forgive my dumbosity but what exactly are the differences between Type S & Type R?
Old Jul 11, 2003 | 11:58 AM
TinkySD's Avatar
Audi Driving Snob
Type Rs in japan are more or less race prepped cars like the integra type R available here for a while. They usually feature modest power upgrades, but serious weight reductions and tuned even more aggressive suspension wise.
Old Jul 11, 2003 | 11:59 AM
larchmont's Avatar
More On
Good Q. I thought they were different terms for basically the same thing.
P.S. But from contexts I did get the idea that maybe it was something like what Tinky just said.
S = taking a basically polite car and making it kind of sporty
R = taking a muscle car and making it more muscle
Old Jul 11, 2003 | 12:33 PM
DEVO's Avatar
The only thing that could happen... and it's a big if.... is for the Accord Euro R comes over... it's a 2.0 liter engine (smaller, less weight) with 220 (around there) hp.
Old Jul 11, 2003 | 01:12 PM
TinkySD's Avatar
Audi Driving Snob
not enough torque in that thing for my taste. The TSX uses a forged crank so I'm betting the weigh tincrase is minimal....50lbs max. What I would be interesting in seeing is the new i-vtec 2.2 litre going into the s2200. That could make for some fun.
Old Jul 11, 2003 | 01:34 PM
typeR's Avatar
well ill give you an email exchange from my guy that used to work for honda R$D in ohio..and you tell me wht you think...note the date of this email and note the accuracy of what has already happened...this was posted july29th at acura -cl oh ya july 29th 2001
.Just got a reply from my freind JC...no not Jesus christ but some of you'll remember the LSD topic awhile back...im so excited so no shit about typing errors...here's a cut and paste...
Everything's going well. You haven't seen any posts from me...but maybe I should. I'm no longer with Honda. I don't know Tuan, as far as I know. It's probably an alias though...seems like he always has the inside scoop and therefore I'd believe that he works for Honda too. The only thing I didn't like about the 6MT CL was the blacked out headlights. (non reflector area is black)...personally I'd get the originals and put on it. I'm not certain, but I think the grille was changed slightly too...or maybe that was just the TL / TL-S. The shift feeling was pretty good on the 6MT and I think most of the linkage is directly from a Prelude. They also replaced the fake wood trim that looks...ahem...fake with nicer fake aluminum trim. The '03 Accord and the '04 TL will kick ass. Also, there were more than rumours that the Euro Accord would come over as an Acura model too.
later
JC
Old Jul 11, 2003 | 02:40 PM
DEVO's Avatar
well it's not that much less, plus it revs higher and is geared to keep it in the sweet spot... the car is lighter so that helps as well.
Old Jul 11, 2003 | 03:41 PM
TSX-S2000's Avatar
Also not likely since the TSX uses a FWD setup and was probably designed without any provision for an AWD conversion. It would be too costly for that to happen (tooling, manufacturing, etc) for a low-production car.
The only thing that I can foresee happening, if there ever is going to be a TSX Type-S, are slightly thicker swaybars for a bit flatter cornering (or less understeer), slightly wider tires (225/45-R17s), and stronger brakes (seems to be a weak point in all the reviews I've read), and maybe another 20-40 horsepower using the same engine. Along with those changes, add power to the passenger seat, heated mirrors, and memory on the driver's seat.
Old Jul 11, 2003 | 04:00 PM
Precision Crafted's Avatar
[QUOTE]Originally posted by TSX-S2000
[B]Also not likely since the TSX uses a FWD setup and was probably designed without any provision for an AWD conversion. It would be too costly for that to happen (tooling, manufacturing, etc) for a low-production car.
The TSX (JDM Accord) was designed with Intergrated Motor Assist in each rear hub producing 50 hp each. Combine that with the current 200 hp (210 reportedly) and you get 300 but increased gas milage. Awhile back on the "other site" I posted info regarding this called "Beyond Type R" as a Honda rep indicated that with IMA they could compete with the M's and AMG's of the world.
If and I mean if Acura does this, it won't be until after the next RL is introduced.
Old Jul 11, 2003 | 06:36 PM
TSX-S2000's Avatar
Does the production-version JDM Accord actually use IMA or was it just done on a concept vehicle? I know Honda has been experimenting with IMA in a couple concept vehicles (such as the NSX replacement) but other than the Insight, I wasn't aware that they've actually produced a real car using IMA.
It sounds like a great idea but I think we're a few years away from seeing any performance-enhancing IMA applications in the U.S. (by that I mean IMA being used mostly for performance rather than fuel economy). The general public in the U.S. probably wouldn't accept a setup like that with open arms -- we are too attached to big gasoline engine.
Old Jul 11, 2003 | 06:50 PM
RJC RSX's Avatar
On the contrary, the euro accord platform has already been developed for AWD. I can see IMA on the TSX a couple years from now...
edit: I just saw your above post (the forums are slow right now). IMA = instant torque on demand, and you would still have the gasoline i-VTEC up front, it's not like it's an electric car. So you get exceptional AWD performance with loads of torque and hp--fuel economy is just a nice byproduct.
Old Jul 11, 2003 | 07:57 PM
"Does the production-version JDM Accord actually use IMA or was it just done on a concept vehicle? I know Honda has been experimenting with IMA in a couple concept vehicles (such as the NSX replacement) but other than the Insight, I wasn't aware that they've actually produced a real car using IMA."
"It sounds like a great idea but I think we're a few years away from seeing any performance-enhancing IMA applications in the U.S. (by that I mean IMA being used mostly for performance rather than fuel economy). The general public in the U.S. probably wouldn't accept a setup like that with open arms -- we are too attached to big gasoline engine."
No. The platform was designed to beable to use it in the near future. As from what I can tell, the new RL will use IMA. Honda made an announcement in Nov of last year I believe that indicated that Acura will have a performance sedan in 12 to 18 mo. that will use IMA.
Old Jul 11, 2003 | 10:48 PM
JeffPhx's Avatar
The Civic Hybrid is the second I believe.
Old Jul 12, 2003 | 12:20 AM
RJC RSX's Avatar
no it's not IMA
Old Jul 12, 2003 | 12:28 AM
jackspat2's Avatar
Hybrid TSX would be something to look at.. I can imagine a v6 in there before a type S on this 4 cylinder. If you're really looking for some more power, mod it out some. Parts will be coming out soon.
Old Jul 12, 2003 | 02:41 AM
InspireS's Avatar
I don't think there will be a Type S version here in North America.
Japan sells the Accord in the following trims:
Base - 2.0L K20 Engine
Premium - 2.4L K24 Engine
Euro-R - 2.0L K20-R Engine (same as the JDM Integra Type R)
I think it will also be highly unlikely they will bring over a Type R for the Integra.
InspireS
Old Jul 12, 2003 | 12:59 PM
RJC RSX's Avatar
"bring over" is the wrong way to think about it. Try "create"
Old Jul 12, 2003 | 01:10 PM
synth19's Avatar
No way will there be a v6 in the TSX, I mean....they would be competing against themselves then (i.e TL)
Old Jul 12, 2003 | 03:17 PM
RJC RSX's Avatar
A V6 wouldn't fit in the tsx, it's as simple as that
Old Jul 13, 2003 | 02:05 PM
wiz's Avatar
wiz
Are you sure about that? It seems like there's an awful lot of room under the hood, at least when I was looking around under there...
Old Jul 13, 2003 | 04:01 PM
RJC RSX's Avatar
Yeah I'm pretty sure. This came from some AHM engineers I talked to, so I assume they know what they're talking about.
Old Jul 14, 2003 | 01:36 PM
TinkySD's Avatar
Audi Driving Snob
nice of them to make sure there was plenty of room for a turbo then
Old Jul 15, 2003 | 01:56 PM
DEVO's Avatar
no it's not IMA
YES it is... I own one, I should know.
Old Jul 15, 2003 | 02:25 PM
RJC RSX's Avatar
ok well by definition, but not in the sense that I'm talking about it :P
Old Jul 15, 2003 | 03:06 PM
ClutchPerformer's Avatar
What sense do you mean?
Old Jul 15, 2003 | 03:11 PM
RJC RSX's Avatar
Well admittedly I'm not 100% sure how the civic hybrid works, other than that it's some gas/electric combo. I was referring to IMA in a performance sense-- electric motors in the rear wheels that produce ~100hp and instant torque in addition to engine power to the wheels up front.
Old Jul 15, 2003 | 03:18 PM
Ah yes. Having 100% torque at 1 RPM is the only good thing about an electric motor in a car. I don't really see it happening on the TSX, though. Maybe in a second generation?
Old Jul 15, 2003 | 03:37 PM
RJC RSX's Avatar
Well it should be on the 05 RL for sure. I'm just speculating in 2 years it could be available (perhaps in a lesser form) as an awd option on other acuras
Old Jul 15, 2003 | 04:30 PM
2004_Acura_TSX's Avatar
Don't get run over!
I should have just waited for the TSX Type S, but too late now. I am happy with the TSX I have now.
Old Jul 15, 2003 | 06:26 PM
RJC RSX's Avatar
you should be no use in waiting for a car that no one is sure of coming out, and if it does, it's likely to be a couple years
Old Jul 15, 2003 | 06:59 PM
swami's Avatar
I talked to some AHM big shots a year or so ago and ask when a pickup was coming out. They said the BIG 4 can have the truck market, Honda's not interested in it. Apparently, they've had a change of heart. Take anything that you hear with a grain of salt.
Old Jul 16, 2003 | 02:45 AM
Raheel's Avatar
Wait I got a question, Isn't the TSX a Honda Accord from Europe?
So doesn't the Euro Accord come in a V6 version? or am I wrong?
Old Jul 16, 2003 | 05:56 AM
Stash's Avatar
you are wrong
Old Jul 16, 2003 | 08:23 AM
StanH's Avatar
Originally posted by ebcheon
[what model from previous acura models changed their engine from a 4 cylinder to a 6 cylinder? or perhaps a 6 cylinder to a 8 cylinder? not a one... [/B]
I'm pretty sure the Legend started as a 4 and put out a V6 model.
