Say Goodbye to Pads, Magnetic Brakes are here
Old 10-21-2003 | 07:05 PM
gavriil's Avatar
Moderator Alumnus
Eddy's Ready To Ditch Discs
By Max Glaskin
It's all over for brake pads and discs. Scientists have invented an amazing 'contactless' braking system that uses invisible magnetic forces to bring your car to a halt. What's more, it's set to revolutionise motoring, as in theory it can be used to power the wheel, too.
The system is known as 'eddy current braking', and it has already proved reliable on rollercoasters around the world for the past 20 years. "The advantage is that there are no moving parts to break down or pads to wear out," said Dr Mark Thompson, an expert from Harvard University, USA. He built the eddy current brakes for the Jurassic Park ride at Universal Studios.
But now US component giant Visteon has patented a design that could be used on cars. The key part is a metal collar that goes around the axle behind the wheel, fixed to the frame of the vehicle. The collar has a series of protrusions sticking out of it. Coils of wire are wrapped tightly around each of these, so when an electrical current is passed through them, a magnetic field is created around the axle.
If the force is strong enough, it can stop the axle spinning. Working in reverse, it's even capable of starting the wheel moving again. John Stubbs, head of technology at the AA Motoring Trust, told us: "It's a good solution because everything that uses friction is bound to wear out sooner or later. This will be one less maintenance operation."
Motorists will still push the middle pedal to slow down, and Visteon's system also features a normal brake for emergencies in case the electrics fail.
Old 10-21-2003 | 07:14 PM
gavriil's Avatar
Moderator Alumnus
Delphi Does A Double in Braking
A new twin-disc brake from the supplier’s labs could mean twice as much stopping power.
by Ian Norris (2003-10-20)
Tucked away on the Frankfurt Auto Show stand of Delphi, the former AC-Delco operation, was a display whose small size failed to signal a development the company describes as "the first significant change in base braking technology since the first volume application of disc brakes more than 50 years ago." The words are those of Chris Baylis, director of engineering at Delphi's Innovation Center in Leamington, England, where the new system has been perfected and is being prepared for manufacture.
The secret of what Delphi calls the "Maximum Torque Brake" is that it replaces the single disc of conventional brakes with two discs, giving four contact surfaces instead of two. The result is up to 1.7 times the torque output of a conventional single disc system of the same effective diameter in a more compact and more efficiently cooled configuration.
Delphi says it believes the new technology will help solve many of the challenges currently faced by braking engineers. Based on a twin floating disc architecture with a single piston, the Maximum Torque Brake provides a high specific torque capability, with substantial improvements in thermal management that can lead to benefits in weight, packaging, and NVH (noise, vibration and harshness).
The guts
Improved thermal management provides engineers with many options for enhancing other aspects of the braking system. By greatly increasing opportunities to optimize the combination of disc size, pedal travel, booster size, and friction material, Delphi says the Maximum Torque Brake will allow the feel, cost, and performance of the system to be precisely matched to market requirements.
For example, with four pad surfaces, Maximum Torque Brake requires approximately half the applied pressure of a conventional disc brake. This could be utilized to significantly downsize the vacuum booster or to reduce the pedal effort and travel. A downsized booster could reduce weight by up to 1 kg (2.2 lb) and provide more premium under-hood space to improve packaging flexibility. Alternatively, disc diameter could be reduced by up to 25 mm (1 inch), allowing smaller wheels (which can generate a substantial cost saving), higher-aspect-ratio tires (important for off-road vehicles) and a significant reduction in unsprung weight.
The superior thermal management of Maximum Torque Brake, and its minimal generation of Disc Thickness Variation (DTV, caused by the discs wearing unevenly) also provides excellent NVH performance. This, according to Delphi, helps to solve the potentially significant problem of noise-related warranty claims, which surveys show is a major consumer issue in the U.S. and the cause of significant warranty costs. "Because the discs are floating on the hub, their contact with the pads is always even. Maximum Torque Brake doesn't have the wear issues or the tolerance stack-up that can cause judder and squeal in conventional systems," says Baylis.
Other benefits of the system include reduced brake fade and, due to the reduction in applied pressure, shorter stopping distances in the event of a vacuum failure - a homologation requirement that can be increasingly challenging to meet using conventional, highly boosted systems. Delphi's claims for the performance of the system are borne out by testing to the independent AMS standards (conceived by the German magazine Auto Motor und Sport) using a BMW X5 fitted with the system. In the twelve-stop test, which is increasingly seen as a European standard, the vehicle demonstrated an exceptional "no fade" performance.
Delphi's testing indicates that in a typical high-performance SUV application, Maximum Torque Brake will remove the need for several brake system specifications, reduce the maximum operating temperature by more than 100 degrees C, improve refinement and offer either reduced pedal travel, by up to 25 mm (due to the reduced volume of fluid required for actuation), or booster downsizing by around 40 mm. Total vehicle weight savings could be as much as 7 kg (15.4 lb), depending on system specification and the level of integration.
The system has completed more than 1.5 million test kilometres in 20 vehicles to help ensure that it will continue to perform to specification in any terrain or usage pattern, throughout a vehicle's life. Two fully engineered implementations have been shown to vehicle manufacturers: one fitted to a Ford Fiesta, a typical B-segment small European car, the other on a BMW X5, a large high-performance SUV. The former has the piston integrated within the suspension knuckle, while the latter demonstrates a standalone piston architecture that could be implemented as part of a mid-life model upgrade.
TCC's representative was among the first journalists to test the new system, driving examples of the Fiesta and the X5 with both their original equipment braking systems and the Maximum Torque brakes. In normal road use, braking efficiency is difficult to judge subjectively, and in both normal braking and panic stops all four cars were totally satisfactory. In terms of the numbers, without a fully instrumented road-test setup, one has to accept Delphi's word that the system is superior.
There was one situation, however, in which the Maximum Torque-equipped vehicles were markedly different, and this was true of both the small 1.4-litre Fiesta and the large 4.2-litre X5. In simple check braking, such as when one leaves a car park and approaches the road, using the brakes gently in order to make sure the road is clear, the Maximum Torque system gave a sharper and more definite response. Without being jerky or snatching, the twin discs had a positive feel that gave confidence in the brakes. It was the only time that the twin system made itself felt, but it was definitely noticeable and gave the driver confidence that the system was in fact more efficient than the conventional single disc.
With an extensive road-testing program completed, Delphi is now working on productionizing the system and has a prototype build layout installed at its Leamington center. Chris Baylis is upbeat about the potential: "With Maximum Torque Brake," he says, "we have a production-ready product that will allow Delphi's customers to introduce a true 21st-century solution for vehicle braking." Delphi says that discussions with vehicle manufacturers are progressing well and that the system could be in production by 2006.
Old 10-21-2003 | 07:37 PM
Zapata's Avatar
Cost Drivers!!!!
huh guess people with pace makers had better steer clear huh?
Old 10-21-2003 | 07:57 PM
Red Nj-s's Avatar
Nuts.
Old 10-22-2003 | 05:58 AM
6mt's Avatar
6mt
i bet acura will still find a way to f*ck it up. they'll find the way to make these vibrate somehow
Old 10-22-2003 | 06:28 AM
zeroday's Avatar
sounds scary
Old 10-22-2003 | 12:26 PM
heyitsme's Avatar
sounds like the same system that is being used in newer high speed trains to move and stop them.
"Capable of reaching speeds up to 300 m.p.h., the TRO8 maglev vehicle goes through its paces at the Transrapid Test Facility in Emsland, Germany. It presents a sleek, wheeless profile."
Old 10-22-2003 | 01:16 PM
mantis23's Avatar
Moderator Alumnus
heh.
Old 10-22-2003 | 01:52 PM
Gilgamesh's Avatar
Our 1995 CNC mill can do this...the spindle motor is capable of going from 10k RPM to stop inless than a second...they simply reverse the poles on the motor, turning it into a generator. Thing is it generates lots of current...the CNC deals with it by dumping it into a large resister that has a 120mm 10k RPM fan moving air over it. The movement of the axes is also stopped this way. Where would they put this current if this is how the system is going to work
Old 10-23-2003 | 07:55 PM
LegendC's Avatar
The Acura Granddaddy
Easy, integrate this into the regenerative braking part of a hybrid car. I believe something similar to this is done on the Insight, but not the Civic Hybrid.
Old 10-23-2003 | 08:04 PM
Deathlok's Avatar
Fear the Bear!
If your electrical system shorts out do you lose your brakes?
At least on a conventional setup you can hit your e-brake... :I
Old 10-24-2003 | 07:46 AM
gavriil's Avatar
Moderator Alumnus
I am sure there will be a backup system.
Old 10-24-2003 | 10:15 AM
danny25's Avatar
Re: Say Goodbye to Pads, Magnetic Brakes are here
there's gonna be a mechanical backup...
Old 10-24-2003 | 11:12 AM
Python2121's Avatar
The hair says it all
when can i see it in a production car?
Old 10-24-2003 | 02:32 PM
NOVAwhiteTypeS's Avatar
hmm i just hope the brakes aren't 'TOO GOOD go form 100~0 in like 2 seconds, im sure tire companies will also have to adjust.
Old 10-24-2003 | 04:32 PM
CLUofI's Avatar
337
if the system could slow and propel a vehicle, then very little energy would be wasted on heat.
Now its time for a .3 liter car that is only powered by electricity. Hello 100 mpg
08_UA7_Gr33k
02-11-2016 02:17 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Say Goodbye to Pads, Magnetic Brakes are here
