Rim question
Rim question
I came up with a few questions about aftermarket wheel fitments. The brembos in the front are very close to the rim insides. I heard a +45 offset is on the accessory wheel. However in the rear, there is more room to play with. I also read we can dip down to a +35 offset on the car (I would only do this in the rear for brake clearance issues) I want to go with a 9 1/2 inch with a 265/30/19 ( extremly close to stock diameter) with the said offset it will only be 8mm closer to the inside housing and 24 or 28 mm closer to the fender.
Any problems you guys see with this?
you also might want to try the temple of vtec tire rack forum. they have their own tire rack representative that answer all questions asked on wheels, tires, offset, etc. he is extremely knowledgable! cy, i think. i would recommend him highly!
http://www.vtec.net/forums/forum?forum_id=146337
