5AT Sequential Sportshift Question
My '99 3.2TL doesn't automatically shift from 1st to 2nd gear and I like that.
How does the new '04TL 5AT work? How does it determine when to automatically shift to 2nd (e.g., redline)?
I'm tempted to shift my order to 6MT at this point. Any help from current owners (neuronbob?) is greatly appreciated.
Thanks.
Thanks.
Re: 5AT Sequential Sportshift Question
Thanks.
Thanks.
I have heard that the 04 is the same way - with the automatic upshift. I'm assuming that in 99, they ran into a lot of problems with people forgetting to shift or intentionally letting the engine bounce of the rev limiter.
The 2004 does, indeed, automatically shift from 1st to 2nd for you. It's just as much a disappointment as it was in the 2000-2003 models.
Re: Re: 5AT Sequential Sportshift Question
Originally posted by ben1233
I have an '01, and it seems to upshift early unless you have the pedal to the metal. Even then, I'm not sure if it runs to the redline. (I've never tried it)
-r
The strength of the SS is third gear on the freeway. That's the gear you're going to drop to on the freeway to pass. The SS will not allow you to downshift if rpms are too high, but AFAIK the car will maintain the top of the rpm range for the gear you are in.
So it's not like leaving it in drive. But a MT provides much better control.
Does it shift based on how hard you're accelerating (i.e., at higher rpm if you're driving in a "spirited" fashion)? Or does it shift early?
The D setting (regular drive) does shift depending on hard you're pushing the accelerator. It shifts down as much as three gears depending on your speed and how hard you press the acelerator, according to the owner's manual.
The SS shifts when you tell it to, except if the rpms are obviously too high or too low for the gear you are shifting to.
It is a disappointment, but IMO, it is not responsive enough to be considered "sporty" or the like.
At least not compared to the SMGII system in the M3. I have not driven Audi's new clutchless system, but I imagine it is also a little better.
The lack of sport is what pushed me to the 6MT.
I'm referring to when the sportshift automatically shifts from 1st to 2nd gear.
Yeah, I agree with this one. If you're sitting behind a semi on a two-lane road and your waiting for an oncoming car to pass, you can bump it down to third and get your revs up. Once the car passes, just press the pedal and you get instant power...then....OFF you go. This is even fun in the '01 225-hp version.
I think we've answered the original question. The SS will shift in the revs get too low or too high. MT is much better.
For the 04 SS - the 1-2 shift is dependent on how hard you are into it. I have seen it shift 1-2 as low as 2,500 rpms at just a slow smooth accel (if you can call it that). After the 1-2 it does hold.
I don't know why some obeject to the fact that it shifts automatically from 1-2 to save you from blowing up your engine. I test drove one yesterday and put it through its paces and rather liked the fact that it auto-shifts if you forget to. If you want o intentionally hit the redline, get a 6MT. I certainly don't want to blow up my engine! WTGAcura!..BTW..I loved the test drive so much..I will be buying one shortly.
in automatic mode, it likes to shift up around 3k RPM, which is way early, and really likes to cruise at gear 5... if your in gear 5 cruising at 45 mph, and you FLOOR IT, you will feel half a second of lag, and then a slight downshift jolt as the car shifts out of an overdrive gear and into 3rd or something, and then you will feel a lot of acceleration once it is in 3rd.
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Originally posted by Fuque:
I think dsl only meant that SS without the 1-2 upshift might more easily allow drivers to damage their engine from reving too high. I don't know if would be true either, just saying I interpreted dsl's comments differently. Certainly anyone familiar with using a MT correctly would not damage an engine.
Ohmygod, however will all those 6MT owners avoid blowing up their engines without an automatic 1-2 upshift?!!?!
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
you can't damage by revving too high--there's a rev limiter (on the MT, it automatically shifts on the AT). You can, however, misshift on the MT, but the SS in the AT won't let you.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
I basically hate shiat like the nav systems that won't let you input a destination while the car is moving, or starter interlocks that won't let you crank the starter unless the clutch is disengaged (or the shifter is in "Park") or the convertible top switch that won't move the top unless the parking brake is engaged. In short, I hate stupid crap that manufacturers put in to reduce their chances of being sued by stupid people because it needlessly inconveniences everyone else. I'm an adult, I can afford a $35,000 car, and I don't need to be treated like a child, thank you very much!
![Grin Fawk](https://acurazine.com/forums/images/smilies/grinfawk.gif)
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
