XM RF mod replacement
Old Mar 25, 2004 | 08:02 PM
anothercls's Avatar
If I buy the blitzsafe cable for my XM radio, would I remove the rf modulator or just replace some wires going in and out of the rf mod?
I am completely lost when it comes to this stuff, so if I sound retarded, I probably am (:
Old Apr 11, 2004 | 04:45 PM
cwisnoski's Avatar
a Blitzsafe would replace your FM Mod. It is a striaght line level connection from your XM to your HU. It usually plugs into your CD changer port or another data port. Some of he blitzsafe leave you the option of adding the cd changer later on.
Alpine does now make a HU with XM built in, no need for a seperate xm unit, you just connect a single line XM antenna to the unit and away you go.
The alpine unit is Alpine CDA-9820XM
crutchfield link
http://www.crutchfield.com/S-CufUm2d...s&i=500CDA9820
have a great day
Old Apr 11, 2004 | 08:30 PM
woodek's Avatar
I installed mine today. Easy install and still have my changer. Worth the $120.00. You'll need a headphone to audio (red/white) cable to interface between the XM cradle and the Blitzsafe. Find it at any radioshack. Try to get one that has the 90 degree plug at the headphone end of the cable.
Old Apr 14, 2004 | 07:12 PM
anothercls's Avatar
Thanks for the info, I will have to find the RF mod in my car, but after that I can get the cables and do the install
I need to cut a piece of out my sunglass holder as well.
Old Apr 18, 2004 | 05:05 PM
asmride's Avatar
7th Gear
I have the Blitzsafe adaptor in my TL-S and it sounds 100% better than FM modulation. Was able to install it without taking the radio out.
Old Apr 18, 2004 | 05:32 PM
anothercls's Avatar
I just spent some time finding the rf modulator that had installed. I will be buying (ordering online) the cable today.
oo7spy
Jun 19, 2023 12:48 AM
TLDude876
Dec 28, 2016 03:18 PM
niray9
Dec 8, 2015 07:34 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
