xm antena
xm antena
im planning on getting xm for the TL and wanted to know from those who have it what kind of antena you have and where you installed it. I was thinking of getting one of those mouse style ones and install in the top corner of the back glass. Any suggestions?
Mobile Elec. Guru
it just depends on how you plan to intergrate it. meaning if you go with a Delphi unit or XM commander then the antenna is supplied as part of the unit. if you go with a direct link one (like sony, pioneer, alpine, etc.) then you would have to get the antenna seperate of the xm tuner. personally i like the smaller antenna that is a part of the Delphi units. as for mounting it, it's a matter of personal preference, as for me i am a nut for symmetry, so obviously i would look to be in the middle of the top of the back window, or perhap on the trunk lid.
well im going with a pioneer unit so i have to get the tuner and a seperate antenna, and i was looking at a good place to put it so i get good reception(sp?) and for it to look good at the same time. I like the fact that our cars dont have any antennas stick out from it and i dont want to really change that now.
Mobile Elec. Guru
well to get to the best possible reception it need to be on the exterior of the car. i think on the edge of the trunk lid or the center of the top of the back window would look as factory as possible.
On the dash will work if you are in an area with lots of repeaters (urban, not a lot of country driving). Otherwise, the antenna needs the plane of a metal surface (trunk or roof) to maximize reception. I have mine on the trunk, centered near the back glass. I love it there and because it's body-colored it totally looks stock.
Chris
Chris
i have sirius but pretty much the same. i mounted mine on the centerline of my roof right near the back window. i plan on replacing it soon cause sirius came out with a lowerprofile unit but im going to stick it in the same location. as far as painting it, go to a local auto paints store and have them mix up your paint color and put it into a spray can and spray it your self
I have my Delphi Roady antenna sitting on my dash, and it has gotten beautiful reception everywhere I've been with it, including rural areas of Oklahoma, Arkansas, Louisiana, and Texas.
Larry
Larry
Lord Ubber
U can even place it inside between the speaker grills.
But most people want to show it off and give the thieves a target.
Pss. You don't need to place it on metal.
I've had mine (XM) on fiberglass and now on the inside.
WITH NO LOSS OF SIGNAL.
I have the antenna that came with the Delphi car kit about a year ago. It's actually a little bigger than what comes with them now I think. I took it to a local body shop and had them paint it the same satin silver metallic that the car is painted--and they did it for free. It's flawless. So much more integrated than the flat black (those are SO General Motors-looking)
Chris
Chris
Chris
Chris
silfa718, I hadn't heard the warnings until after I had it painted. You can imagine how surprised I was to read people saying not to paint because the metallic in the paint would interfere with the reception. All I can say is that I took it to the Honda body shop, said "paint this satin silver metallic." The end result is that it looks identical to the paint on the car and it functions properly.
If the paint was a problem, how do you explain all the new Accords and TLs running around with them painted? Is the paint different from what they use on the body of the car? I'm genuinely curious about this.
paint is going to be paint no matter where it came from. if it has metalics in it its usually just a metalic flake. i dont see it causing a problem. maybe if there was tooo many layers, but still kinda doubtful
Ziff700
06-05-2005 08:25 AM
