Wiring Help
Old Dec 28, 2001 | 03:15 PM
1StGenCL's Avatar
958 & 991
Wiring Help
Sorry for the stupid questions but i dont want to screw up. I have a 600 watt, 2 channel amp that i want to bridge to one channel at 4 ohms to power a sub. Im running an 8 guage power cable down the passenger side with an inline 60 amp fuse about 12" from the battery to the power terminal on the amp. Then i am running the RCAs down the drivers side with the remote wire but I'm not sure what to hook the remote wire to on the headunit. I have an adapter on my factory harness to fit my after market radio and from the wiring side harness (connecting factory harness to new harness) i have a blue wire. Is this the wire i am supposed to use for the remote? I also have an unused blue/white wire coming from the back of the radio harness that says "system remote control" Which one do i use? Also how do i bridge my two channels into one? thank you so much
Old Dec 28, 2001 | 03:26 PM
1StGenCL's Avatar
958 & 991
Ok i just used a test light and found that the "system remote control" wire gets power when the radio is turned on so is that the remote wire i am supposed to use? Thanks
Old Dec 29, 2001 | 03:37 PM
1StGenCL's Avatar
958 & 991
Please help someone must be able to tell me how to bridge two channels to one and if that is the right wire? Please....
Old Dec 29, 2001 | 04:42 PM
SilverKnight's Avatar
Retired. Not available.
if the wire gets power when the HU is on then it's the right wire.
If you want to bridge 2 channel into 1, be sure your amp is capable. If it is, then it should have marking on the speaker out terminals. Good luck.
Old Dec 29, 2001 | 05:54 PM
hiepdocl's Avatar
CL first
600 watts use power cable & ground cable 4 gauge is the right way.
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
