Wiring help.......
Old Aug 3, 2001 | 02:09 PM
VTEChump's Avatar
Wiring help.......
Anyone know how to bypass the parking brake wiring so a Pioneer DVD monitor will function while the car is in motion. Is it just a 12V signal or will I need something different???
Old Aug 3, 2001 | 03:20 PM
SilverKnight's Avatar
Retired. Not available.
Originally posted by VTEChump:
<STRONG>Anyone know how to bypass the parking brake wiring so a Pioneer DVD monitor will function while the car is in motion. Is it just a 12V signal or will I need something different???</STRONG>
Read the screen manual. In my case (Panasonic screen), it's a ground signal. I believe yours should be ground as well since the parking brake switch only produces ground.
Old Aug 3, 2001 | 03:52 PM
VTEChump's Avatar
Have you wired a switch to try it out at all??
Old Aug 3, 2001 | 10:12 PM
acuradan69's Avatar
Heres what you do, hook that wire up to the same point where you hooked up your ground wire. When you hook it up to your parking brake it only grounds when your parking brake is activated, thus if u hook it up to the same point your ground is, its constantly grounded
watch tv and drive at the same time....yay!
DAN
acuradan69@aol.com
Old Aug 4, 2001 | 02:07 AM
Originally posted by acuradan69:
<STRONG>Heres what you do, hook that wire up to the same point where you hooked up your ground wire. When you hook it up to your parking brake it only grounds when your parking brake is activated, thus if u hook it up to the same point your ground is, its constantly grounded
DAN
acuradan69@aol.com</STRONG>
I did my screen mostly for the fun of it and a little showing ... but watching it while the car is moving? I leaves that to the passengers
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
