Wiring the door speakers
Has anybody had experience threading wires through the doors for the speakers? Is it really hard or does it just seem hard. I would appreciate any information concerning this issue. Thanks!
Or.. you could send a flexable wire from the the speaker side through the groomet then attach the speaker wire to it then pull it back through.
I would not use vaseline. Vaseline has a breakdown effect on rubber. Like..Never use vaseline to put on a condom.
(And that concludes todays sex class).
i just ran a wire in my driver side TL door last week, the hardest part is getting the wire into the boot, there are a few empty spaces in the actually harness connector, if you use 16 or 18 gauge wire or higher size, the wire will easily fit
Some have removed the grommet to run wire through. It can be a pain to put back, but if you work it little by little it will go back in. You could also disconnect the door limiter/stop & that will give you more room to work with.
Originally Posted by StreetEffectz
Wire hanger + liquid soad = no headaches
Maybe liquid soap would have helped!
Jul 16, 2017 07:33 AM
polish_pat
Sep 25, 2015 12:24 PM
