Wireharness kit Question?
Old Dec 16, 2003 | 03:45 AM
Rob2000TL's Avatar
I have a 2000 tl with the bose ... I am putting in my aftermarket pioneer , do I just use the standard harness (accord harness, I THINK ) ? someone told me I have to get a special harness along with the regular harness. because of the bose ... IM CONFUSED ... I am hearing 2 different stories... Do i have to replace the factory speakers? I know I will lose the factory sub... no big deal .. sounds bad anyways.... some one that has experience with this please help... or has done it in there car,...
Old Dec 16, 2003 | 07:14 AM
AcuraX2's Avatar
The harness you referred to works fine. You do not have to change the speakers but, you will want to. I originally changed the head unit to an Alpine 7893 without changing the speakers and it sounded decent. It will not hurt anything to do that. You will be able to judge for your self if you need to change the speakers.
Old Dec 17, 2003 | 02:19 AM
Rob2000TL's Avatar
what size are the speakers for the front and back ?
Old Dec 17, 2003 | 06:47 AM
AcuraX2's Avatar
Alot depends if you want them just to drop in or if you want to modify. Almost any 5 1/4 will fit without modifying the door. Almost all 6 1/2 will require a spacer and cutting of the door. I have Diamond M661's in my front door and had to trim the door very slightly at the bottom.
Old Dec 17, 2003 | 08:41 PM
Try to look for 5 1/4 with no more than 3 inch depth. I believe you would lose the sub but no sure about that.
Old Dec 18, 2003 | 09:36 AM
Scott P's Avatar
Mobile Elec. Guru
Here's the skinny on changing the radio and the speakers: AcuraX2 has it all right. You will need the 98+ honda accord harness, you will lose the sub (which really isn't that big of a difference) and you don't have to change the speakers even though you will want to to get better sound reproduction. 5.25 will pretty much just drop in but you might as well go ahead and get 3/4 to 1" spacers and use 6.5"s ( the factory speakers use a 3/4" spacer) the mounting depth available is approximately 3" and the diameter of the factory cut hole is approximately 4" so you can use those sizes when considering speakers should you feel the need to change them.
Old Dec 21, 2003 | 11:11 PM
so there is no way to change the hu and keep the stock sub?
Old Dec 22, 2003 | 08:28 AM
Scott P's Avatar
Mobile Elec. Guru
the only way i can think of that you could do it would be to use an afermarket amp running off the head unit and the wire the amp to the stock sub.
Old Dec 22, 2003 | 09:28 AM
but i thought the factory sub had its own amp?
Old Dec 22, 2003 | 02:31 PM
fsttyms1's Avatar
the accord doesnt have the sub. so the harness isnt wired for it
Old Dec 22, 2003 | 07:27 PM
oh okay that makes sense...so if i want to keep the stock sub i cant use the wireharness.
BoricuaTL
Apr 8, 2016 01:08 PM
IIDXholic
Oct 8, 2015 02:27 PM
datadr
Sep 12, 2015 09:12 PM
Nicho863
Sep 3, 2015 09:16 PM
datadr
Sep 2, 2015 06:46 PM
