Wire Codes For Alarm...
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|black/white |- |drivers kick panel *2 |
| POWER UNLOCK|black/red |- |drivers kick panel *2 |
| PARKING LIGHTS +|red/black *3 | |grn plug above fusebox |
| PARKING LIGHTS -|green/yellow | |factory alarm (if equipped) |
| HEADLIGHTS|red/wht (low) 12awg|+ |steering column |
| DOOR TRIGGER|lt. green/red *4 |- |drivers kick panel *2 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|green |- |*6 |
| HOOD PIN|yellow/red |- |drivers kick panel |
|TRNK/HTCH RELEASE|blue |- |at switch *7 |
| FCTRY ALARM ARM|factory remote only | | |
|FCTRY ALRM DISARM|factory remote only | | |
| TACHOMETER|blue | |distributor *1 |
| SPEED SENSE|orange | |instrument cluster |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|gray or blu/grn |- |steering column |
| WIPERS|blue & blu/yel *5 |- |steering column |
| LF WINDOW UP/DN|red/blu - red/yel |A |in drivers door |
| RF WINDOW UP/DN|blu/yel - blu/grn |A |in drivers door or dkp |
| LR WINDOW UP/DN|green - grn/yel |A |in drivers door or dkp |
| RR WINDOW UP/DN|yel/grn - yellow |A |in drivers door or dkp |
| SUN RF OPN/CLOSE|grn/red - grn/yel |A |sun roof switch |
| RADIO 12V|white/blue |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA|yellow/green |+ |radio |
| LF SPEAKER|blu/grn - gry/blk | |radio |
| RF SPEAKER|red/grn - brn/blk | |radio |
| LR SPEAKER|blu/yel - gry/wht | |radio |
| RR SPEAKER|red/yel - brn/blk | |radio |
Notes:
*1 Also found in a 16 pin white or gray plug to the left of the fusebox. *2 In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch. *3 Also a male blade terminal is available in fuse box. *4 Looks like 14 awg wire but mostly insulation. *5 Use both and diode isolate each. *6 12 pin blue plug on top center of fusebox. *7 Trunk release only works with the doors unlocked.
Notes:
2002 tl
| POWER LOCK|black/blue |- |passenger fuse box *1 |
| POWER UNLOCK|orange |- |passenger fuse box *1 |
| LOCK MOTOR|white/red | |drivers fuse box *2 |
| UNLOCK MOTOR|yellow | |drivers fuse box *2 |
| DISARM DEFEAT|lt. green/red | |passenger MUX module *3 |
| PARKING LIGHTS +|red/black | |passenger kick panel |
| PARKING LIGHTS -|red/yellow | |left of steering column |
| HEADLIGHTS|blue/red |- |left of steering column |
| DOOR TRIGGER|black/white |- |passenger fuse box |
| TRUNK/HATCH PIN|blue/green |- |drivers fuse box |
| HOOD PIN|yellow |- |passenger fuse box |
|TRNK/HTCH RELEASE|white/red |+ |passenger MUX module *3 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|blue |- |drivers door key cylinder |
| TACHOMETER|blue | |drivers shock tower *4 |
| SPEED SENSE| | | |
| BRAKE WIRE|white/black |+ |brake switch |
| HORN TRIGGER|lt. green/blue |- |steering column |
| WIPERS|blue & blue/yellow |- |left of steering column |
| LF WINDOW UP/DN|red/yel - red/blu |A |drivers window motor |
| RF WINDOW UP/DN|blu/wht - blu/yel |A |RF window switch |
| LR WINDOW UP/DN|red/blu - red/yel |A |LR window switch |
| RR WINDOW UP/DN|red/blk - red/yel |A |RR window switch |
| SUN RF OPN/CLOSE|grn/yel - grn/red |A |relays left of fuse box |
| RADIO 12V|white/green |+ |radio |
| RADIO SWITCH|white/red |+ |radio |
| POWER ANTENNA| | | |
| RR SPEAKER|red/yel - brn/wht | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555H or 555U. *1 Located in a green 20-pin connector. Use the key switch in the passenger door to test. *2 Located in a green 18-pin connector. *3 The passengers MUX module is located behind the glove box. *4 In a 2-pin connector near the air intake on the drivers side shock tower.
| SPEED SENSE| | | |
Notes:
Jamus22
06-11-2023 10:08 AM
SUPRMN84
10-07-2015 09:46 PM
