Will Bass mess with my NAVI? 2nd Gen TL
Old Apr 30, 2005 | 08:02 PM
Doc Holliday's Avatar
Question Will Bass mess with my NAVI? 2nd Gen TL
Should I put some dynomat or something around my NAVI in my trunk or something?
I'm running two 10" mtx 4500's with 420 watts in either a sealed or ported enclosure... I was going to either fire them towards the trunk or fire them up towards the empty hole left by the stock eight inch sub.
If I fire them up towards that hole will the bass mess with my amps and navi?
Old May 1, 2005 | 03:08 AM
ou sig's Avatar
Boomer SOONER
my navi hasnt missed a beat with my subs at all...
Old May 1, 2005 | 07:43 PM
Question 2 Questions
1. Are you firing your subs up towards the rear deck or towards the trunk?
2. Did your Cap make a difference?
Old May 1, 2005 | 08:28 PM
ou sig's Avatar
Boomer SOONER
the subs are pointed to the back of the trunk - I believe that is by far a better setup than firing them up at the rear deck.
2. the cap...well that is an interesting question. you will find people that swear by them and others that say dont waste your money. I am in the middle of the road on it. I got it for a few reasons, first was because it has a voltage readout, so I can monitor the voltage going to my amps (kinda cool) and the other, because I didnt know how the stock electrical system would like the 1100+ watts from my amps.
it also really depends on if your amps have "regulated" or "unregulated" power supplies. http://www.caraudioresources.net/tec...wersupply.html
If they have a regulated power supply you wont need a capacitor because the amp will provide the same output power (watts) from a wide range of voltage - the whole point of a capacitor is to help keep the voltage that is going to your amps at a steady 14.4 volts. With amps with unregulated power supplies, when the voltage drops, so does the output power of the amps. Kicker amps have "loosely" regulated power supplies - so they dont drop power as quick, but still can benefit from an external capacitor to help keep the voltage up high. So in a nutshell - an external capacitor will not hurt anything, it will only help the amps, and they are also known for keeping noise out of the system, (though, a common ground for all your amps will do the same thing).
Old May 1, 2005 | 08:36 PM
ou sig's Avatar
Boomer SOONER
here is a picture of my capacitor
Old May 1, 2005 | 08:44 PM
dark inspire's Avatar
El Presidente
did u eliminate the plastic pass-thru door?
Old May 1, 2005 | 08:46 PM
ou sig's Avatar
Boomer SOONER
no, its just down in the picture. I can put the door and/or the armrest back up so you cant even see the capacitor
Old May 1, 2005 | 08:48 PM
El Presidente
slick!
Old May 2, 2005 | 12:03 AM
blumpkin's Avatar
o-qua tangin wann
i've had trouble with my navi bc of the bass
i'm going to have the unit moved and dynamatted tho
especially since i plan on another Xtant 1001x
emailnatec
29
Sep 28, 2018 04:27 PM
RSpyder
Sep 30, 2015 12:46 AM
thegipper
Sep 28, 2015 01:01 PM
Acura604
Sep 28, 2015 12:24 PM
jmaxima03
Sep 27, 2015 10:22 AM
