Wierd amp/box problem
Old Apr 22, 2004 | 09:01 AM
drZaius09's Avatar
I recently installed two 12" subwoofers in a custom box with a 350w amp in my '97 CL 2.2 ...
Everything seemed to be fine as I finished up all my wiring, but when I got in my car to take a ride the bass was missing in action. I pulled over to check things out, popped the trunk, and BOOM, bass kicks back in. So I checked all the connections, made sure no wires were getting pinched, shut the trunk, and the bass stopped again. WTF!?!?! I went back home, pulled everything out and put everything back together, still won't play with the trunk closed. Keep in mind there are NO wires ANYWHERE NEAR the trunk or the trunk latch. The only thing I can think of at this point is the ground wire, which I attached to the bracket that holds the jack... but even that is to the side of the tail-light assembly, at least 2-3 feet from the trunk latch.
Before I start moving stuff around again, I wanted to see if anyone here had any insight, or possibly know where I could go to find some.
Thank you.
Old Apr 22, 2004 | 09:19 AM
03typeS6spd's Avatar
misanthropist
never heard of anything like that...
could the amp be overheating when you turn it up???
the sub is wired incorrectly for the amp (what ohm is everything?) and the amp goes into protect?
Old Apr 22, 2004 | 11:47 AM
drZaius09's Avatar
All I can say is that I used this same box with the same speakers and the same amp in my old car (which had much, much less trunk space), and I never had a problem with overheating.
Old Apr 22, 2004 | 11:52 AM
drZaius09's Avatar
Update: I also just tried taping the truck latch (actually the metal ring that the trunk latches on to) with electrical tape, covering every square inch of metal just to see what would happen... but it did not help. I'm at work now so there's not too much else I can do before I get back home.
Old Apr 22, 2004 | 12:39 PM
Nicky Pass's Avatar
Fuct in the hed!
Check you grounds...
Old Apr 22, 2004 | 02:05 PM
phipark's Avatar
Not Asian
Doesn't sound like you have a very good ground. Move to another spot. Make sure you are making contact with bare metal with nothing else much attached. A true ground should have it's own point by itself.
Old Apr 22, 2004 | 05:17 PM
Jonesi's Avatar
Agreed...!
Old Apr 22, 2004 | 09:28 PM
Slooo97CL's Avatar
its most def the ground, make sure its metal and scrape the paint off the metal too. bad ground = cutting out.
Old Apr 24, 2004 | 11:09 PM
1-cl-2-go's Avatar
A-CL Auto-Tech
re-ground your cables to an existing ground like a bolt that already has wires grounded to it. if that works just drill a hole, under or above that ground spot and tighten your cable to a nice size bolt near the existing terminals
Old Apr 25, 2004 | 10:27 AM
Slooo97CL's Avatar
i found that if you ground near the spare tire, that metal corrodes and is a terrible spot, ground more towards the rear seats.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
