Where to tap in the LOC on 3G for amp and sub?
I have searched everywhere for this info, but still can't find it. Got an 05 TL with navi and I'm trying to install and aftermarket amp and sub. Where does the line out coverter tap into, which wires? And where do you guys tap in the remote wire if somewhere other than the fuses? Someone told me that all those wires to tap in can be found at the sub, correct me if I'm wrong.
Should I remove the old sub?
Thanks in advance.
Thanks in advance.
I think that these speakers have stock amps, so the headunit doesn't have +/- wires coming out of them directly to the speakers. That's why I can't figure out which wires to tap into.
https://acurazine.com/forums/showpos...7&postcount=13
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/hfl-after-market-amplifiers-nav-724235/
Hope that helps. If you do the install and can snap some pics to throw a DIY together it would be appreciated by many on the site.
@ the Stereo Amplifier in the passenger kick panel in the 20 pin Black & White connector
RF+ Black
RF- Gray
LF+ Green
LF- Blue
C+ Brown
C- Greeen w/White
RR+ Orange
RR- Red
LR+ White
LR- Yellow
SW+ Red w/Blue
SW- White w/Green
Remote Turn-on -> Red w/Yellow
Amp Mute -> Yellow w/Green
In addition ....
@ the Stereo Amplifier in the passenger kick panel with the 14 pin gray connector contains the speaker outputs if you want to utilize the factory wiring.
RF+ Blue
RF- Red
LF+ Light Green
LF- Purple
C+ Green w/White
C- Blue w/Yellow
RR+ Red w/Blue
RR- Yellow
LR+ Brown w/White
LR- Red w/Yellow
SW+ Yellow w/Black
SW- Light Green w/Red
Ground -> Black
+12V -> White
RF+ Black
RF- Gray
LF+ Green
LF- Blue
C+ Brown
C- Greeen w/White
RR+ Orange
RR- Red
LR+ White
LR- Yellow
SW+ Red w/Blue
SW- White w/Green
In addition ....
RF+ Blue
RF- Red
LF+ Light Green
LF- Purple
C+ Green w/White
C- Blue w/Yellow
RR+ Red w/Blue
RR- Yellow
LR+ Brown w/White
LR- Red w/Yellow
SW+ Yellow w/Black
Ground -> Black
+12V -> White
Acura604
20
08-05-2017 12:55 AM
soupi
14
11-15-2015 11:15 AM
InFaMouSLink
10-30-2015 09:43 AM
