Where to tap in the LOC on 3G for amp and sub?
Old May 9, 2009 | 10:32 AM
konrad1's Avatar
I have searched everywhere for this info, but still can't find it. Got an 05 TL with navi and I'm trying to install and aftermarket amp and sub. Where does the line out coverter tap into, which wires? And where do you guys tap in the remote wire if somewhere other than the fuses? Someone told me that all those wires to tap in can be found at the sub, correct me if I'm wrong.
Should I remove the old sub?
Thanks in advance.
Old May 9, 2009 | 10:41 AM
on1wheel01's Avatar
When I had my stock hu on my 97 cl I went in behind the stock hu, it sounded better and more clear than at the speakers. Not sure if this helps
Old May 9, 2009 | 10:57 AM
mattastick's Avatar
Unless you bought a LOC designed to handle amplified signals, you need to tap into the wires as close to the factory hu as possible.
Old May 9, 2009 | 11:42 AM
konrad1's Avatar
I think that these speakers have stock amps, so the headunit doesn't have +/- wires coming out of them directly to the speakers. That's why I can't figure out which wires to tap into.
Old May 9, 2009 | 01:57 PM
on1wheel01's Avatar
well not sure if its the same but mine are factory bose amplified amps in the rear.
on1wheel01's Avatar
well not sure if its the same but mine are factory bose amplified amps in the rear. and it still has wires behind the hu
Old May 10, 2009 | 10:28 PM
konrad1's Avatar
Still can't figure it out... bump...
Old May 10, 2009 | 10:52 PM
Jonesi's Avatar
I dont know where the stock amp is and I dont have a wiring diagram but that's where you want to tap in..
Old May 10, 2009 | 11:09 PM
Jonesi's Avatar
https://acurazine.com/forums/showpos...7&postcount=13
@ the Stereo Amplifier in the passenger kick panel in the 20 pin Black & White connector
RF+ Black
RF- Gray
LF+ Green
LF- Blue
C+ Brown
C- Greeen w/White
RR+ Orange
RR- Red
LR+ White
LR- Yellow
SW+ Red w/Blue
SW- White w/Green
Remote Turn-on -> Red w/Yellow
Amp Mute -> Yellow w/Green
In addition ....
@ the Stereo Amplifier in the passenger kick panel with the 14 pin gray connector contains the speaker outputs if you want to utilize the factory wiring.
RF+ Blue
RF- Red
LF+ Light Green
LF- Purple
C+ Green w/White
C- Blue w/Yellow
RR+ Red w/Blue
RR- Yellow
LR+ Brown w/White
LR- Red w/Yellow
SW+ Yellow w/Black
SW- Light Green w/Red
Ground -> Black
+12V -> White
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/hfl-after-market-amplifiers-nav-724235/
Hope that helps. If you do the install and can snap some pics to throw a DIY together it would be appreciated by many on the site.
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
