Where to run 4 ga power through the fire wall?
Old Aug 11, 2004 | 01:17 PM
demolition_x's Avatar
Agean Blue Bishes
im looking to run power line to my amp but i couldn;t find any where to run the wire. where did you guys do it. i really don;t want to drill through any thing but i will if i have to. thanks if you got pics that would be greatly appreciated.
Old Aug 11, 2004 | 01:59 PM
shawhite's Avatar
what year tl.. if its the second gen then there is a plug a little to the right and a couple inches above the gas pedal you will see a rubber plug pull that out and behind it is a grommet that leads to the engine bay... if you look in the engine bay towards the middle of the firewall up top you will see it.. you have probably already seen it but dismissed it due to you thinking it was to high up to actually go in the car under the dash.. i can take pictures if you still cant find it..
Old Aug 11, 2004 | 02:05 PM
Agean Blue Bishes
i'll take a look how far up from the gas pedal are we talking.... if you don;t mind taking the pic it would help. thanks
Old Aug 11, 2004 | 08:34 PM
Rusky's Avatar
My baby's daddy
You can't miss it!
Grab a flashlight, point it at the gas pedal. Now, go up and slightly to the right. There is a circle as clear as the nose on your face. There may be a plug of the foam backed carpet material there as well. I went through this as well. From inside the engine compartment, it looks very high, as Shawshite pointed out, but it's perfect. Just push it into the car from the outside with a screwdriver, dril a hole in it (or punch one), and there you go.
Old Aug 12, 2004 | 08:20 AM
steveinathens's Avatar
i ran my 4 guage wire through this hole as well. and bought a grommet from partsexpress...
http://www.partsexpress.com/pe/showd...number=263-722
perfect....
Old Aug 14, 2004 | 11:44 AM
AA7483's Avatar
Registered Pimp
how about on the 04 tl?
Feb 25, 2020 09:57 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Sep 15, 2015 06:44 PM
spoiler900
Sep 10, 2015 01:06 PM
