What wrong???
Old May 8, 2009 | 01:57 AM
nayaab88's Avatar
What wrong???
Sometimes my sub just stops hitting and the bass gets very weak. This has happened a couple times. My bass controller would be turned up all the way but it barely hits. I just turn it off for a while and then its back to normal. Any ideas on what could be causing this?
Old May 8, 2009 | 02:25 AM
dave586270's Avatar
Chamorro
Maybe a bad ground?
Old May 8, 2009 | 06:16 AM
D.Greenwood13's Avatar
2000 WDP
What kind of amp do u have?
Old May 8, 2009 | 01:02 PM
nayaab88's Avatar
I have an Infinity 1300a, I think the ground is fine becuase the amp is on, but the sub just stops hitting or hits very weak.
Old May 8, 2009 | 01:08 PM
Jonesi's Avatar
Are you sure it's not overheating?
Old May 8, 2009 | 02:06 PM
xaznperswaesonx's Avatar
Is it a Dual voice coil? If so, one of your voice coil is either burnt or the leads that connects to the voice coil has came loose.
Happened to me once with my RF power punch Dual 4ohm.
Old May 8, 2009 | 07:31 PM
nayaab88's Avatar
Now that I think about it. That might be the problem. Does the bass get weak when overheating occurs?
Old May 8, 2009 | 08:40 PM
mattastick's Avatar
nayaab, you're most likely overheating the amp. And yes, what you're experiencing happens when you overheat an amp. There are a couple of ways to fix this. 1) Make sure the amp has enough room around it. 2) Put a fan on the amp, so it has air constantly moving around it. Another option is to put some kind of spacer underneath the amp's mounting feet so that the bottom of the amp isn't resting on anything.
Old May 9, 2009 | 03:28 AM
TISIXER's Avatar
to add to those suggestions, you may want to reconfig your amp frequency settings (settings too high for outage may set the amp to go in protect mode), of course you wont have much bump
acuratl26
Apr 23, 2020 07:30 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
rangomango
California
Sep 24, 2015 05:47 PM
Hines57
Sep 24, 2015 01:58 PM
