What wrong???
What wrong???
Sometimes my sub just stops hitting and the bass gets very weak. This has happened a couple times. My bass controller would be turned up all the way but it barely hits. I just turn it off for a while and then its back to normal. Any ideas on what could be causing this?
Is it a Dual voice coil? If so, one of your voice coil is either burnt or the leads that connects to the voice coil has came loose.
Happened to me once with my RF power punch Dual 4ohm.
nayaab, you're most likely overheating the amp. And yes, what you're experiencing happens when you overheat an amp. There are a couple of ways to fix this. 1) Make sure the amp has enough room around it. 2) Put a fan on the amp, so it has air constantly moving around it. Another option is to put some kind of spacer underneath the amp's mounting feet so that the bottom of the amp isn't resting on anything.
acuratl26
04-23-2020 07:30 PM
Hines57
09-24-2015 01:58 PM
