What is this wire?
Old Jan 1, 2006 | 05:11 PM
Tennisjon2002's Avatar
What is this wire?
I have been having some trouble with the FM radio on my HU on my 97 accord LX. It keeps fading out and stuff. The Hu is a sony. I am not really looking at dropping any money in this car so don't start hating on the HU or installation job etc, I promise I am not responsible for these
I put the stock HU back in and the radio worked fine so it is either the HU or the wiring harness. I think it is the wiring harness due to how crappy it was installed etc. My question is what is the wire that is circled? It seems to be my problem
Old Jan 3, 2006 | 10:09 AM
ngravatt's Avatar
2013 sh-awd adv
i think that is the antenna remote wire. But im not sure exactly what it does.
Old Jan 4, 2006 | 04:41 AM
CL'er 1st & 2nd Gen's's Avatar
Acura loyal for 93mo/109k
Wire is for a power antenna. Activates when AM/FM is selected.
Old Jan 4, 2006 | 11:59 AM
Tsx536's Avatar
Rep'n Taxbrain.com
That is the power antenna or remote turn on wire. It can be used for either purpose. If you have a power antenna that goes up and down, then it would control that. It can also control turning your aftermarket amps on and off.
If you have no aftermarket amps and you don't have a power antenna, then it's okay if this wire is disconnected. I forget what the antenna is like on a 97 accord.
Old Jan 4, 2006 | 01:27 PM
ngravatt's Avatar
2013 sh-awd adv
its to power the antenna only. if you look at the picture, you can see the remote wire for the amps.
You COULD use this as the amp remote wire, but the amps will only turn on when you are using the FM or AM radio.
i have never had to connect this wire, but i have also never had a 97 honda
Old Jan 4, 2006 | 04:49 PM
Ok so when I connect the above to like a ground I get "ATT on" displayed on the head unit, so I think it is for the romote thing u can get. There is already another wire attached to the power antenna wire. I checked all the connections in the wiring harness and they are all ok. I am running out of ideas
The 97 accord, or atleast the LX which I have, has the antenna in the rear window. I have taken the power antenna wire apart and reconnected it and it is the same. I have also done this for the ground, 12v power etc, all of them but the speakers
http://www.crutchfield.com/S-atFuKIo...ech/kb299.html
crutchfield gave me some ideas but sadly none of them worked.
Old Jan 4, 2006 | 05:33 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Oh okay I see. I've never had a Sony car radio before. I'm not as familiar with the wiring harnesses. Some of the other stereo manufactures treat the remote turn on wire and the power antenna wire as the same thing. It's usually the only solid blue wire also.
Old Jan 4, 2006 | 05:47 PM
yea there is a solid dark blue wire i believe for the power antenna. damn sony. i am trying to decide if I should just try a new wiring harness, get a cheap new alpine, give up and accept no radio, or take this somewhere to be looked at.
Old Jan 5, 2006 | 09:09 AM
ngravatt's Avatar
2013 sh-awd adv
Tennisjon2002,
you do have the antenna connected to the back of the radio, dont you?
Old Jan 5, 2006 | 11:09 AM
Tennisjon2002,
ha yes I do. I wish it was a problem that easy Any more ideas or suggestions of what to do
Old Jan 5, 2006 | 10:46 PM
I think I am gonna just buy a new wiring harness and start from scratch and install it properly this time. I know I can buy the harness from the stock hookup but can I buy the part that clips into the back of the radio then connects to the part connecting from the stock adapter. (I explained that really bad), I am talking about the wiring that goes from the HU to the adapter, can I buy a new set of that?
Old Jan 9, 2006 | 12:31 PM
ngravatt's Avatar
2013 sh-awd adv
yeah, get it from the HU manufacturer. i have ordered harness for my old head units when the wires get too short to use.
Old Jan 9, 2006 | 01:43 PM
+well I got a new car wiring harness thing from walmart yesterday and the reinstalled my HU with crimps and actually did it right and it this time. it is workin right now
Old Jan 9, 2006 | 01:45 PM
elduderino's Avatar
VP Electricity
Thank God for Wal-Mart, eh?
Old Jan 9, 2006 | 01:49 PM
hell yea walmart is the shit It was only $6 though so that is pretty good. At Best Buy they are like $20
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
