What to use for remote lead?
Old Oct 23, 2002 | 06:26 PM
Simpleman's Avatar
the last one alive
So on my Basslink, I used the factory WHITE/YEL (Constant Power) for the remote lead, but I don't think this is right. It Basslink stays on all the time- but makes sense with the whole 'constant' power and all. I didn't know what else to use for remote at the time. I didn't see a factory remote lead in SilverKnight's/Shawn's wiring code.
Old Oct 23, 2002 | 06:48 PM
mcdanjw's Avatar
There should be a YEL/WHT wire that is the turn on lead for the factory amp you can tap...
Looks like you may have tapped the inverse color scheme...
Old Oct 24, 2002 | 12:55 AM
Simpleman's Avatar
the last one alive
I tried the YEL/WHT, and it didn't even turn on the amp. Also, the YEL/WHT is supposed to be the Radio Switch, isn't it?
Old Oct 24, 2002 | 07:16 AM
mcdanjw's Avatar
YEL/WHT is the wire I used for my turn on lead...
It should work.
Are you tapping this wire in the trunk or somewhere else?
Old Oct 24, 2002 | 12:19 PM
Simpleman's Avatar
the last one alive
WTF? I know I tried tapping into this wire and it didn't work. Damn. I guess I'll just try it again.
Hey, what about the WHT/RED (ACC) per http://acuracl.dyndns.org/monkeymato/audio3.jpg ?
It should work.
Old Oct 24, 2002 | 12:25 PM
mcdanjw's Avatar
If you're tapping the connection to the back of the deck, that red/wht wire should work.
Do you say you were tapping the wire in the trunk or in the dash?
Old Oct 24, 2002 | 02:20 PM
Simpleman's Avatar
the last one alive
In the trunk. I don't remember seeing the whit/red wire, but maybe that's because it's only in the front.
I'll try the yellow/white wire again this weekend.
Old Oct 24, 2002 | 04:12 PM
Six Shifter's Avatar
an adult perspective
The YEL/WHT is the proper lead for remote turn-on of your amps. I tapped into mine behind the HU and ran a lead which allows for the proper turn-on of my EQ and my JL Amps.
Old Oct 26, 2002 | 05:36 PM
Simpleman's Avatar
the last one alive
looks like the yel/wht IS the remote lead. the crimp i was using was a bit wonkey, but all is working now. thanks!
Old Oct 26, 2002 | 06:03 PM
mcdanjw's Avatar
Glad it worked out!
You had me perplexed!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
