What speakers did YOU use?
For those that have replaced their front door speakers with 6.5s, what did you use? Do you like it? Was there something else you were interested in?
Just trying to get as many ideas as possible for what might fit in the car and then choose among those.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I went with audiobahn because I was on a tighter budget and I got them for wholesale. I also looked at JL, boston, and eclipse, but went cheaper, like my audiobahns for now though
I went with DLS Iridium's in front and DLS UR6S in the rear (both 6.5's) Couldn't be happier. I was considering Focals, but have decided this was a better choice.
The only problem is the depth of the magnet. I have a TL so it may vary from your TSX, but I don't see this speaker fitting in any vehicle without modifications.
Not Asian
Boston Pro60
Very pleased, although they sound probably twice as good with the quality install. My guy made some nice speaker rings and sealed them off very well. I used to have Kicker Resolutions, still have them in a box somewhere, and the Boston's put them to shame. The Kickers are just too harsh.
Also consider, DLS, Dynaudio. I'm not a fan of the big brand companies, ie Alpine, for speakers.
I used polk db6500's in the front.
I had to make spacer rings for 'em, it was easy and other than that it's a perfect fit.
The tweeters (6500's are components) required a little bit of trimming of the stock tweeter holes.
overall, a pretty easy swap.
Boston Z6
Used in my previous car, not installed in my TL yet, but will be soon.
One of the best 6.5 component speakers on the market. The sound reproduction is amazing.
Alos, if you "don't see this speaker fitting in any vehicle without modifications," then does that mean you had to modify your door to get them in?
^^ Second to the infinity components. Its a good drop-in set (with metra brackets) for a nice bang-for-the-buck upgrade. I think it was the 60.3s components. I have a whole install thread on it somewhere you could look up.
Originally Posted by TallestTSX
It's interesting you say that because I heard specifically that the DLS UP6s weren't as deep as most speakers. Is that not the case, or were you speaking specifically about the Iridiums?
Comparison:
![](http://www.grandmarkie.com/DLS/2_both.jpg)
UR6's
![](http://www.grandmarkie.com/DLS/3_ur6s.jpg)
Iridiums:
![](http://www.grandmarkie.com/DLS/1_iridium.jpg)
I didn't modify the door panel itself, but created a baffle/shim for the speaker, which was certainly necessary for my car.
![](http://www.grandmarkie.com/dynamat/speaker.jpg)
Originally Posted by phipark
In the trunk....
![](http://img208.imageshack.us/img208/4967/1000527edited0ms.jpg)
Not Asian
Nice setup. Did you ever get that amp or whatever it was that was missing back in the trunk there? Also, do you have any closeups of the different pieces? Wanted to see how you finished it off.
I went with Boston Pro's in the front doors. They are running off a JL 300 2. The Amp is under the driver seat and the crossovers are under the passenger seat.
Not Asian
Originally Posted by UNeeKLiNG
did you take out your spare tire or did you just elevate the setup?
Not Asian
Originally Posted by kyotousa
Hi I am wondering if I should just change the rear deck speaker......
put Polk MOMO MMC 690 in...will that work with the rest of stock system?
CDT HD-62's. Extremely happy with them. I put the x-over in the doors.
http://www.streeteffectz.com/jordantl/
'99 Acura 3.2TL
im using soundstream components for the front and soundstream 2-way speakers for the back... sounds good... amplified with a 5-channel soundstream tarantula amplifier (which also powers my sub)... feeded by a motorized panasonic headunit (7-channel EQ).
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
Diamond Audio 6.5 s600 Hex-FRONT
Diamond Audio 6x9's -BACK
JL Audio 12W3V2-SUB
Alpine MRV-F450
XM Commander Radio Unit
I have the Diamond Audio crossovers and line driver under the carpet in the front seats. I had to cut about 1/4" of the sound insulation to alllow for a flush fit. My next plan is to install a Audio Control 4.1i in-dash EQ to help dial in my music since I only have bass and treble control with the factory head unit. At the same time I do this I plan on putting sound deadening material in the doors, trunk and the floor when I have a very boring weekend : )
JL Audio 12W3V2-SUB
Alpine MRV-F450
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
rboller
09-23-2015 02:49 PM
