what do u guys think of this sub?
Old May 15, 2003 | 03:26 PM
car_lost's Avatar
momo polk audio MM104... here are the specs:
Overall Frequency Response 20Hz - 200Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 500 w
Power Handling (peak) 1000 w
Efficiency 85 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Magnet Weight 66.00 oz
Driver Mounting Depth
Top Mount 5-1/4" (13.34cm)
Bottom Mount 5-5/8" (14.29cm)
Driver Cut-out Diameter 9-1/4" (23.50cm)
Theile/Small Parameters
Recommended Enclosure Sealed or Band Pass
Resonant Frequency 32 Hz
Qms 11.83
Qes 0.486
Qts 0.467
Vas 31.79
Cms 189 Micro Meters
Bl 14.65 Tesla Meters
Sd 346 sq. cm / 53.63 sq. in
Xmax (mechanical) 1.0
Le 2.17 mH
Mms 129 g
Driver Weight 14.8
tell me what u think.
Old May 16, 2003 | 08:59 AM
dnd2984's Avatar
ITs not that bad of a woofer. What amp will you be using. Amps will have the most impact on the woofer.
Its great sounding woofer and its polk. Alll polk does is make speakers so u know it one of the better woofers in the market, even though u can just pick one up at circuit city.
Old May 16, 2003 | 10:02 AM
car_lost's Avatar
so if i can get it for less than $100... brand new... should i go for it? im not worried about the amp yet... im intrested in getting the subwoofers first nd then finding a compatible amp.
Old May 16, 2003 | 12:26 PM
dnd2984's Avatar
Hell yea for a $100 bucks I would get it.
OculiAquilae
Nov 19, 2018 02:24 PM
funkbro2
Nov 17, 2015 10:23 PM
knight rider
Oct 1, 2015 10:29 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
Nicho863
Sep 3, 2015 09:16 PM
