what do i need for ps2?
Old Jan 17, 2004 | 06:58 PM
njtls's Avatar
what do i need to be able to install a ps2 in my car?...thanx
Old Jan 17, 2004 | 07:09 PM
shawhite's Avatar
power inverter...
Old Jan 17, 2004 | 07:40 PM
njtls's Avatar
thats it?...ok thanx
which one do i get tho...how many watts do i need?
Old Jan 17, 2004 | 07:56 PM
vipvop's Avatar
do you even need an inverter? Since the ps2 uses an AC adapter you can prolly figure out what current it needs DC wise, and skip the inefficient conversion from dc - ac - dc.
Old Jan 19, 2004 | 10:27 PM
jpadilla's Avatar
I've been trying to figure this out for a while, having to use an inverter is B.S. I know u have no choice for XBOX since it uses so much damn power, but PS2 should not be a big deal.
Old Jan 19, 2004 | 10:35 PM
njtls's Avatar
i'll stick with an inverter just to be safe...the only probablem is i cant find a small one to hide in the car
Old Jan 19, 2004 | 11:23 PM
e_lectro's Avatar
Still here
I think this is something you might be interested in, PS2 on 12V without an inverter: http://www.asdffdsa.net/car/howto/ps2_in_car.htm
Old Jan 20, 2004 | 12:14 AM
jpadilla's Avatar
Well that looks simple enough, except I would also like to use it in the house ... oh well cant ask for too much. Thx.
After looking at the wiring diagram, it appears that it can accept both 120VAC and 12VDC. Cool, I didn't ask for too much!
Old Jan 20, 2004 | 12:22 PM
njtls's Avatar
thanx..but im really not good with that stuff...i just need to find a small inverter....also...would i have heat problems with the inverter if the space is too confined?
Old Jan 26, 2004 | 09:35 PM
GSteg's Avatar
Depends how much current you're trying to yank out of that inverter. The more current you're pulling, the more heat it's going to generate. If you get a small inverter and run it to the max, it's going to get hotter than an inverter that is bigger (assuming everything else is constant). One reason is a bigger heatsink. More surface area .
acuradan69
Apr 25, 2003 04:57 AM
kchen_RENAMED
May 10, 2002 02:36 AM
jacobzking
May 7, 2002 01:38 PM
Hoffhines
Mar 21, 2002 03:34 PM
