What is it called?
Old Dec 7, 2004 | 10:46 AM
phil217's Avatar
Bit*h get in my car
What is it called?
What is the thing called when you want to use your stock head unit and have a system? Does anyone recommend any brand any any experience with it? Im planning on getting 2 JL Audio 12w3v2 and a 500/1 amp so I was just wondering...thanks again
Old Dec 7, 2004 | 10:47 AM
Dan Martin's Avatar
Photography Nerd
Line Output Converter?
Old Dec 7, 2004 | 11:01 AM
elduderino's Avatar
VP Electricity
NOOOOOOOO!
(Read the sticky on the TSX system...)
I think the 500/1 will take a speaker level signal if you're just tapping the 6x9's ... check the manual at jlaudio.com
Old Dec 7, 2004 | 01:08 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Originally Posted by elduderino
NOOOOOOOO!
Old Dec 7, 2004 | 03:37 PM
Bails's Avatar
NOOOOOOOO!
It does, and it works great! I will be running a 500/1 to my W7 12 as soon as i find time to install it. Ive installed a few 500/1 's in TL's using the speaker level inputs and didnt have any problems. A line converter would probably induce engine noise b/c it wouldnt be able to handle the amplified signal you would be running to it from the tsx's factory amp. If you still want to use a line coverter, audiocontrol just came out with their LC6, which is designed to upgrade premium factory sound systems. www.audiocontrol.com
Old Dec 7, 2004 | 04:01 PM
elduderino's Avatar
VP Electricity
Waste of time. Why use an LOC in a car with a preamp single-ended signal? Why use an LOC with an amp which has one built in?
BTW, the TSX OE amp does not have more power than an off-the-shelf LOC can handle. At best, it's an 8-channel high-power deck. The AudioControl LC6 is really intended for cars like the Mercedes where the optical digital data bus goes straight into the amp, and you can't get audio signal anywhere except at the outputs of the amp. That's a much more powerful amp than the TSX amp. (Of course, the LC6 has other problems in that situation, but I'll let AC respond to those problems...)
Also, I would differ with you on whether engine noise is caused by an amp overpowering an LOC. Engine noise with the use of LOCs is not caused by OE amps overpowering the LOC.
Old Dec 8, 2004 | 07:10 PM
Bails's Avatar
i stand corrected.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
thegipper
Sep 28, 2015 01:01 PM
