What is it called?
Bit*h get in my car
What is it called?
What is the thing called when you want to use your stock head unit and have a system? Does anyone recommend any brand any any experience with it? Im planning on getting 2 JL Audio 12w3v2 and a 500/1 amp so I was just wondering...thanks again
Originally Posted by elduderino
NOOOOOOOO!
(Read the sticky on the TSX system...)
I think the 500/1 will take a speaker level signal if you're just tapping the 6x9's ... check the manual at jlaudio.com
VP Electricity
1 Post
Waste of time. Why use an LOC in a car with a preamp single-ended signal? Why use an LOC with an amp which has one built in?
BTW, the TSX OE amp does not have more power than an off-the-shelf LOC can handle. At best, it's an 8-channel high-power deck. The AudioControl LC6 is really intended for cars like the Mercedes where the optical digital data bus goes straight into the amp, and you can't get audio signal anywhere except at the outputs of the amp. That's a much more powerful amp than the TSX amp. (Of course, the LC6 has other problems in that situation, but I'll let AC respond to those problems...)
Also, I would differ with you on whether engine noise is caused by an amp overpowering an LOC. Engine noise with the use of LOCs is not caused by OE amps overpowering the LOC.
08_UA7_Gr33k
02-11-2016 02:17 PM
