What amp to get for mids and highs?
Old May 17, 2001 | 12:25 PM
3.2-TL's Avatar
Post What amp to get for mids and highs?
As i have already said i have a ms2250 1000 watt pheonix gold amp for my lows. What is the best p/gold amp i could get for my mids and highs? Thanx.
P.S. I was origainally going to get a 4 channel 2000 watt amp for everything but which was going to give 1000 watts for mids and highs,simpl;y because they had told me that it was best since i could adjust my gains with my crossover.
Old May 17, 2001 | 05:07 PM
autophile1's Avatar
Post
what speakers will you be using?
Old May 17, 2001 | 06:03 PM
3.2-TL's Avatar
Post
3 12"kicker solobaric L7 (square ones). They are already installed in my ride. Thanx
Old May 18, 2001 | 05:24 PM
3.2-TL's Avatar
Post
Originally posted by autophile1:
No, I meant what speakers will you be using the new amp for...
For now i'm guessing the stock speakers. Not sure yet.
Old May 18, 2001 | 11:39 PM
autophile1's Avatar
Post
Old May 18, 2001 | 11:41 PM
Post
Try to go with any amp that has a high pass filter on it.
Old May 21, 2001 | 06:22 PM
Post
IMHO get at a 4 channel p/gold amp with at least 100 watts per channel for your mids and highs. Whatever amp you do get make sure the output doesn't exceed the power handling of the speaker.
Example puttting 200 watts into a 45 watt speaker. Can you smell the smoke
The 4 channels will allow you to fade front to back and balance left to right. If you get alot of watts you might want to think about upgrading your electrical sys. aka high output alternator, second bat. stif.caps. etc.
A big system will tax your stock alternator.
Hope the info helps.
Frank
Old May 21, 2001 | 08:46 PM
preludeshfan's Avatar
Post
personally i never run more than 35-50 watts per channel when it comes to coaxials or separates. a lot of people dont understand that if you go with 100 watts rather than 50 per speaker you will only get 3db louder. it takes 2 times the power to get 3 db louder and 3 db is what is considered to be perceptivly louder meaning that the human ear can detect a difference if the volume increases by 3db. so for a measley 3 db why pump 100 watts to each speaker? all your going to do is start burning up voice coils. and consider the fact that the front speakers are pointing in your general direction anyway. you really dont need a lot of volume to make them loud. the stock TL stereo only has 12 watts per speaker and granted it is not the loudest system 36 watts is triple the power. and at 9 db louder the system will be more than loud enough for most people.
Old May 21, 2001 | 11:27 PM
Post
preludeshfan you are right in your post...I recommended the higher watts only because it seemed 3.2tl was going for a high power system. Under most circumstances 50 watts is plenty of power...Different strokes for different folks.
Old May 23, 2001 | 12:17 PM
3.2-TL's Avatar
Post
Thanx for the info guys. Now i'm sure those peeps telling to get 1000 watts for my mids and highs because I had a 1000 watts for lows are dickheads.
DerrickW
Nov 15, 2015 05:52 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
San Yasin
Sep 29, 2015 10:52 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
ceb
ILX
Sep 27, 2015 10:56 AM
