VTEC Light
Old May 16, 2002 | 02:47 PM
Angry VTEC Light
I was reading the FAQ about the Vtec light and thought, "What the heck." So I wired everything with exactly the same part numbers and all was going well, right up to the point I got to the ECU. There I find that it is bolted with 10mm bolts. Two are easy to remove, the third is all but impossible. Then there are two little bitty screws on the top and bottom of the ECU. This was really not an issue seeing that I was still able to pull the lower and middle plugs. Mine are orange, not grey. Upon looking at the wires on the middle plug I found the green wire with a yellow stripe, but there are two of them, not one. I tapped into one of the two hoping it would work. Now when I turn my car on, the LED light comes on for about 1 second and then turns off. It is not coming on again at all. I am hoping I just tapped into the wrong wire of the two, but before I go pulling everything apart again I want to make sure I'm even going in the general direction. I tried to E-mail the original writer of the FAQ sheet, but I am being told the administrator disabled the function. Hoping someone out there can help. Thanks!
-Chris
Old May 17, 2002 | 02:39 AM
VeiLsTyleZ's Avatar
i tired to do the same awhile ago and now im where you are...
the light just turns on for one sec, when you turn on the car...then i drove it around, hit VTEC nuttin happend.
at that time i didnt see a second green wire tho ...so i put everything back to normal. but i still have all the parts i need..so i you get it right can you post it? thanks
did you try the two green wire?
Old May 17, 2002 | 03:10 PM
The guy who originaly wrote the direction wrote them for a Prelude, not a Type S. Anyway, he said that he will probably know which wire for our cars in two weeks. If I have time today or tomorrow I will grab a tech and get a test light and try to figure it out. Otherwise, we'll be waiting for two weeks. No big deal.
Oh yeah, I did try the other green wire, nothing at all happens with that one.
-Chris
Old May 22, 2002 | 02:07 AM
VeiLsTyleZ's Avatar
-Chris
yes please let us know
Old May 25, 2002 | 01:56 AM
randomwalk101's Avatar
Wrote it for a prelude but posted as instruction for TL? Isn't that pathetic? I'm glad I haven't tried it out yet.
Old May 25, 2002 | 02:35 AM
asiankidd's Avatar
dood whats your problem...its people like me who put in the effort to explore things like this that spark ideas....if you ask me your just a d*ck....why dont you go figure it out yourself if your so great...:thefinger
Old May 25, 2002 | 08:56 AM
SwampGas's Avatar
/etc/car
Eek! Don't say that!
You *KNOW* someone is going to have their friend sit in the front seat, they'll floor it to engage VTEC and then say "Duuuude, like hookup the multimeter and see if the wire is electrified man!"
And of course when he yanks the ECU wire out...
Accident waiting to happen
Old May 25, 2002 | 11:38 AM
Sask32TL's Avatar
Nothing suprises me. As EVERYBODY here knows, Acura is just the luxury division of Honda, and a lot of parts are identical between certain models of Honda and certain models of Acura. Same also applies to wire harnesses. Why build and inventory two different harnesses when you can do the job with one???
Old May 29, 2002 | 01:45 AM
If the schematic is for a Prelude, then say it's for a Prelude but it MIGHT work for TL or whatever. As far as I'm concern, you're just another little chink d*ck talking out of your a** :thefinger:
Old May 29, 2002 | 04:09 PM
cyumbrk's Avatar
7th Gear
VTEC only works when the car is moving. Go inside your engine bay, find your VTEC silonoid, get the green wire. Tap into the green wire with another wire and run that inside your car. Hook that wire up to your led and then hook the other wire to the led to a ground. Start it up and then go driving. I did it and it still works fine, btw I have a 99 Accord.
Old May 29, 2002 | 11:18 PM
asiankidd's Avatar
go look at my post i did say it was for a prelude it just the mods took it to the faq the way it is now....right back at you:thefinger
do a search under ultimate rice you will seee what i said
Old Jun 6, 2002 | 08:57 PM
Tripnbeats's Avatar
sask32tl
Yea dude all ac's r hondas but if nuttin impresses u maybe the prices would (only diff for god sake the emblem on honda accord costs 25 bones the one on 3.2tl type S is 129 do the math):wow: :wow:
Old Jun 6, 2002 | 09:23 PM
asiankidd's Avatar
sorry about the wait guys...got finals next week....i'll get on it after wednesday....
JON LERD
__________________________________________________
2nd annual SOCAL joint tl/prelude/cl meet june 22nd
http://www.acura-tl.com/forum/showth...threadid=40155
mada51589
Jan 9, 2025 04:40 PM
Dunnik
Sep 15, 2015 11:52 PM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
