voltage question
Old Sep 21, 2007 | 12:51 PM
smazzurco's Avatar
Question voltage question
Ok, so i have a 06 tsx w/ nav. I'm using mercman's cable and a BALUM adapter provided by him. My amp, a pdx-1.1000 has an input voltage selector switch, with the two options being .1-1v and 1v-8v. Anyone know what the actual voltage at the amp would be? With the setting on .1v-1v the bass is it a bit "strong" lol (which might be correct) and with it on 1v-8v it seems a bit weak (but i could always pump up the gains if needed).
Just wondering what i should be using. Thanks in advance
Old Sep 21, 2007 | 01:41 PM
jiggaman's Avatar
I spend 2 much time here
is it balun or balum?
i see people spelling it both ways...
Old Sep 21, 2007 | 02:05 PM
smazzurco's Avatar
honestly me personally, i have no idea. But i have seen it refered to as BALUM. Maybe its like center/centre, both work, stand for different things but mean the same thing
Old Sep 21, 2007 | 02:10 PM
jiggaman's Avatar
gotcha, i wish i could answer your original question, i also wish i had a Balun/Balum... damn non-balanced amps!!!!
Old Sep 21, 2007 | 04:21 PM
Castles_Saloon's Avatar
its called a BALUN, as in BALanced to UNbalanced.
Voltage range...
The stock amp has a gain of roughly 10. with a 14V power supply rail, it would clip with 1.4V input. That means the closest voltage range to select is .1-1V. However, the stock radio could exceed your 1V limit slightly at very high volumes. at medium volumes, .1-1V is optimum. just turn down the bass a wee bit.
Have Fun!
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
